• 10-23-2017
    OlMarin
    diesel as cleaning solvent
    I'm sure everybody knows this, but diesel fuel is a good cleaning solvent that's great for us cheap [email protected][email protected]*ds. A gallon for around 3 bucks? Try to beat that. And for those of you who have a motorcycle with an O-ring chain, it won't destroy the O-rings.
  • 10-23-2017
    127.0.0.1
    yeah
    how about no
    diesel leaves a residue. then you need to clean that residue with,
    wait for it, another solvent.
    kerosene is the better and safer cleaning solvent if you are going to be using
    something by the gallon and cheap. it is about the same thing as diesel as a 'fuel oil' but kerosene is a known and common industrial cleaning agent... no one uses diesel if kerosene is available
    all diesel can do is cut thick crap and leave thin crap behind.
  • 10-23-2017
    OlMarin
    ^^ depends on what you're cleaning. I don't care if it leaves a residue on, say, my chain. Gonna lube it anyway. Same with derailleurs and such. Dish soap works well to get rid of the residue left behind on stuff you want purty. As stated, I'm a cheap [email protected][email protected]*d. I wouldn't be a life long bicycle commuter if I weren't
  • 10-23-2017
    Harold
    pray tell, where do you put the dirty, used diesel fuel?
    there are places it's really better NOT to be a cheap bastard.
  • 10-23-2017
    OlMarin
    Back in the coffee can from whence it came. When it gets REALLY dirty I usually have used motor oil to recycle. Yes I'm so cheap I do my own oil changes on the truck, lawn mower, snow blower, etc.
  • 11-03-2017
    Rider-at-night
    I use to clean my chain with that, but that was when I worked in the gas station, I was collecting the small amount that remains in the hose after the pump stops working, it wasn't cheap it was free!!! But that's nasty and leaves a mess, I wouldn't recommend it.
    But now I just go to the market and buy a kitchen degreaser, a few squirts and the stuff wipes the grease and dirt easily, wash and rinse with water and then a little spray of wd40 to push the water out of the roller bearings. Clean, wipe, and leave it to dry. Then lubricate, wipe after a few minutes or a ride, and presto.
