Cracked Frame today on commute need advice- Mtbr.com
Results 1 to 2 of 2
    Jul 2014
    Upset Cracked Frame today on commute need advice
    Like the title says my frame cracked on my commute home today. All of a sudden weird noises and slight drag on the rear wheel so I stop. Quick release seems loose so I tighten. Try to get going same thing, walk the next 1/4 mile home lucky. Grab the work stand tighten the quick release again replaced the chain since I hadn't done it since the spring and thought that's where the drag was coming from. Took the bike for a test drive and have a popping noise that still felt like it was coming from the drivetrain that wasn't happening when in the stand. Put it back up in the stand took the rear wheel off thinking the freehub had come loose or something and felt the derailleur move A LOT. checked the hanger it was loose so I tightened it and finally saw this crack (well complete failure) in the drop out. Bike in a box anyone? Going to try to get to get a warranty frame on the Kona but for now I'll ride the trek may convert it to drop bars later in the week. 700cs won't fit under the fork of the trek so I can't switch to the studded tires for now.
    I have been looking at surly troll and ogre frames for about year but couldn't pull the tigger as my frame was still working for me. I want to run drop bars on either frame. I am leaning towards the troll as I could run larger 26" tires but I would like to run 700c tires up to 40 mm.
    So finally to the question, what would you choose a troll or an ogre and am taking suggestions on size? The Kona Jake was a 56cm so I think an 18" troll is what I would be looking at.
    Attached Thumbnails Attached Thumbnails Cracked Frame today on commute need advice-image.jpg
    Bedwards Of The West
    Oct 2007
    Ogre Ogre Ogre Ogre Ogre Ogre Ogre Ogre
    (no excuse for that either)
  1. Replies: 4
    Last Post: 04-03-2015, 07:09 AM
  2. How was you commute today? (Vol 2)
    By 755872 in forum Commuting
    Last Post: 07-31-2014, 11:23 AM
  3. Storck adrenaline frame cracked need advice
    By Charliebukol in forum General Discussion
    Last Post: 07-11-2013, 01:52 PM
  4. Cracked AL Frame Advice
    By UpillDaemon in forum 29er Bikes
    Last Post: 10-17-2012, 04:00 AM
  5. advice on a cracked Wily frame
    By Keyaroxy in forum Frame Building
    Last Post: 11-23-2011, 05:19 AM
