converting single speed to 1x9- Mtbr.com
Results 1 to 8 of 8
    Hi all, first id like to thank you for all the info ive learned on these forums, i lurked for a long time before joining and its been a huge help. right now i commute on a mtb with slicks and am pretty satisfed but also would like to try something else. my question is, how hard would it be to convert a single speed in to a geared bike? what do i need to look for on the bike to be sure that it will work? im interested in this because i love the aesthetics of flat bar single speeds but where i live i need something to help on hills and flats. thanks in advance for your help!
    The best way to keep the aesthetics of a flat bar single speed is to use an internally geared hub (IGH). Shimano Alfine, Sram Nexus, Rohloff, etc. You can often find a pre-built wheel with the shifter and everything for around $300 on the low end.
    Now are you wanting to convert your existing bike or do you want to convert something new?
    Jason
    Disclaimer: www.paramountfargo.com
    well i suppose i should say that this is all a money saving thing, basically i dont want a full on road bike with drop bars etc and on my current bike i never leave the big cog. i see so many cheap single speeds and id like to get one then eventually make it geared 1x9 so i guess im really asking what a i should look for on a bike to make the conversion possible.
    Derailleur hanger and cable, cassette, chain, and shifter should be about all you need. What kind of dropouts?
    "I have one speed. I have one gear: Go." -- Charlie Sheen
    Single Speeder
    Reputation: Your Bike Sucks's Avatar
    Quote Originally Posted by ender. View Post
    What if there is no derailleur hanger on the SS frame? Can one be fabricated to bolt on?
    "There's little traffic on the extra mile".
    Quote Originally Posted by Your Bike Sucks View Post
    I believe there are options, that is why I asked what type of dropouts. Also I am pretty sure some lower end derailleurs come with integrated hangers. I have learned all this just from a little google searching, so I am by no means an expert.
    weirdo
    Reputation: rodar y rodar's Avatar
    Hi, Nhilist. Welcome.
    Old school RDs had those claw mounts, but I kind of doubt they`d work with a horizontal dropout, especially without the little screw hole. Can`t remember- did the screw just go into a fender mount, or was it a hole just for that purpose? Most of the bikes that had those claw mounted RDs came with mid length slanted dropouts.
    You can have a derailler hanger added to a steel frame, but that isn`t the economical way of doing things unless you can do it yourself. Might be able to get it done with aluminum also, but that would be really expensive.
    I think Jag nailed it.
    EDIT: Okay, Sheldon has it and it`s cheap:
    http://harriscyclery.net/product/var...r-claw-963.htm
    Looking at the picture reminds me where the screw goes- right through the wheel slot, and into that funky little moon shaped nut.
    Wierdo
    Dec 2005
    Also, what kind of rear hub are you running? If it's a dedicated SS hub, you'll need to switch to a conventional hub that will accept a cassette.
  1. Advice on converting a single speed to 9 speed??
    By Norsman29er in forum 29er Bikes
    Last Post: 01-04-2010, 08:01 PM
  2. Converting to Single speed
    By Chim Chim in forum Singlespeed
    Last Post: 11-02-2009, 09:47 PM
  3. converting to single speed on an XTC
    By xsport652 in forum Weight Weenies
    Last Post: 09-10-2008, 08:56 PM
  4. Converting a dos to Single speed
    By sandmangts in forum Salsa
    Last Post: 03-14-2008, 11:17 AM
  5. Converting to Single speed
    By Zonk0u in forum Downhill - Freeride
    Last Post: 07-03-2007, 04:47 PM
