• 03-22-2018
    urbsuburb2017
    Commuting: Winter tires to spring/summer/fall tires on a Pugs
    I've been winter commuting about 10 miles a day (city/suburban asphalt) on my Pugsley, with 3.8" Nates inflated to about 8-10 ppi. No problems with snow or potholes.
    Good weather is on the way (eventually), and I'm thinking about changing out the Nates for something more appropriate. I've got a set of Knards sitting around. I could either switch them out and go from there, or maybe get a set of Black Floyds for the warm months.
    Also thinking about getting a set of Rolling Daryl or Marge Lite drilled rims, same idea.
    Guy at the local LBS also suggested just inflating the Nates to maybe 14 lbs - cheapest solution.
    What would you do?
  • 03-22-2018
    leeboh
    Checked out some Vee Speedsters? Way slick.
