Is the Claris an 8-speed? If so, you would need a different hub to go to 11 speed so I don't think that will work.
I just upgraded my 3x8 system to 3x10 105 group by changing the shifters and cassette. That works fine. I suspect you can use a triple shifter. You would probably want to set it up to use the higher 2 gears which would mean that it would click down to the smallest chaingring position but nothing would happen because the limit screws would stop it.
Yeah, your hub needs to be 11spd compatible to make the switch on a road bike. Some, like Mavic, have been 11spd compatible for a long time. Others have not.
- You may not post replies
- You may not edit your posts
Forum Rules
