Cheap Fixed commuter frame? reposting this here- Mtbr.com
Results 1 to 7 of 7
    I already have a set of Mavic CXP 22 wheels and just want to get a frame to use as a college commuter.
    I know I might get ragged for asking about an ebay frame, but I'm on a cheap budget.
    its either this
    http://cgi.ebay.com/NEW-ROAD-BIKE-CY...DLWI%26ps%3D54
    this
    http://cgi.ebay.com/EIGHTHINCH-SCRAM...d=p4999.c0.m14
    or this
    http://cgi.ebay.com/NEW-ALUMINUM-TRA...d=p4999.c0.m14
    I'm sure they are all fairly equal and I should just get the cheapest one.
    The first one would seem to be more flexible regarding fender clearance and rack mounts, also if you are thinking "V"s or cantilevers its the only option.
    No-Brakes Cougar
    Reputation: Gary the No-Trash Cougar's Avatar
    I would also go with the first one, the Motobecane. It's the most expensive of the three, but it's a cross frame with a bit more relaxed geometry so it might end up being a little more enjoyable to ride on a regular basis. And as theindividualist mentioned, you have way more tire clearance. Fatter tires will give you a softer ride and better traction. But if you really want to save a couple of bucks and/or you really prefer a stricter track geometry then you can't go wrong with the eighthinch or Dawes frames either.
    R.I.P. Ronnie James Dio ~ July 10, 1942 May 16, 2010
    Frt Range, CO
    Reputation: pursuiter's Avatar
    Quote Originally Posted by Gary the No-Trash Cougar
    I would also go with the first one, the Motobecane. It's the most expensive of the three, but it's a cross frame with a bit more relaxed geometry so it might end up being a little more enjoyable to ride on a regular basis...
    clearence is great, head angle is 74*...have you seen the Pake c'muter:
    http://www.pakebikes.com/pakemute.html
    Not as much clearence as the Motobecane, head angle is 72*, that's relaxed
    The Pake very looks interesting - very similar geometry to a cross check with the added bonus of having lowrider mounts, a few $ cheaper than a Surly but still $120 more than the Motobecane.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=360138610940
    Reputation: joshed's Avatar
    Dude.
    Urban Outfitters.
    http://bikes.urbanoutfitters.com/
    jrm
    jrm is online now
    Reputation: jrm's Avatar
    yeah
    but youd need to run tugs for sure..
