Canyon Endurace cf sl disc + thule chariot?- Mtbr.com
Results 1 to 6 of 6
    Dec 2013
    I just got an endurace for commuting, and im keen on attaching my thule chariot sport 2 trailer.
    Having no experience with flimsy roadbikes, will it handle the extra 30kg ish on the side of the rear axle without distortion when braking or pulling?
    Thule doesn't make rear axles that work 100%. The closest is the x12 syntace m12x1 and 160mm long axle, but the head is conical, whereas the original is flat. The thule head has a small flat surface at the inside. I'm thinking of either make a custom shim in the lathe with a counter countersunk hole, or just use a flat steel shim. ( I'm a lazy guy) Any input?
    Sent from my SM-G950F using Tapatalk
    Jan 2009
    I'm not familiar with that bike or trailer, but did you look at Robert Axle Project?
    For example: https://robertaxleproject.com/shop/1...mount-trailer/
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
    Dec 2013
    Hi. Yes, it looks ok, but is not a perfect fit either. You have to shim it out because the threaded hole on the dropper is not a thru hole.
    I will make the thule work, but im most concerned about a bike weighing 7.6kg pulling a 30kg trailer.
    Dec 2013
    Made this now, so it fits.
    Dec 2013
    Seems to work allright
    Reputation: ghettocruiser's Avatar
    The adapter looks slick.
    All I can offer is that I pulled a chariot for 5+ years with a bike that didn't have much more material on the stays, and a regular QR, and a disc brake in the way, at speeds and on routes that were dubious choices for a prudent parent, and nothing amiss ever happened.
    The above statements have not been evaluated by the Food and Drug Administration
  1. 2018 Canyon Spectral CF 8.0 vs 2019 Canyon Spectral CF 7.0
    By mastershredder in forum All Mountain
    Last Post: 02-16-2019, 05:24 PM
  2. Lux CF SL 7.0 Race vs Lux CF SL 6.0 Pro Race
    By gontxo_nos in forum 29er Bikes
    Last Post: 08-08-2018, 10:19 AM
  3. YT Jeffsy 29 CF vs. Canyon Spectral CF 8.0
    By cer20 in forum General Discussion
    Last Post: 07-06-2018, 04:58 PM
  4. Canyon is Here - Endurace CF SL Disc - $1999
    By Erik_A in forum Cyclocross
    Last Post: 08-23-2017, 09:46 AM
  5. Canyon CF SL 6.9 vs CF SL 7.9
    By olivierhacking in forum Canyon
    Last Post: 12-05-2014, 06:37 AM
