Brakes Swap?- Mtbr.com
Results 1 to 5 of 5
Thread: Brakes Swap?
    Jul 2014
    Brakes Swap?
    I have a basic commuter bike that has mechanical disc brakes, for awhile now i've had problems with stopping with them. The front brake has gotten to the point where it just won't brake anymore no matter how hard I hold it. I have the brakes adjusted and a week or two later they go back to their old not wanting to stop ways.
    The bike is about 10 months old.
    I was contemplating converting to basic brake pads. Don't really know bikes that well, but I do love to ride them! Not sure if this is a good idea or even possible. I ride it every day in any weather usually about 10-12km a day. Ideas or options would be greatly appreciated!
    Thanks in advance!
    Quote Originally Posted by cowarch View Post
    Thanks in advance!
    check for oil on the pads...or just get new pads
    Reputation: watts888's Avatar
    Oct 2012
    Assuming it's just the rotor/pad and not an alignment issue.
    Mechanical discs are much better than traditional rim style pads, especially for a commuter in rain or shine riding. Oil on the pads/rotors sounds like a guilty culpret, and wiping the rotors with rubbing alcohol will help. Shouldn't be the silver-bullet though. I've taken the pads out of my brakes, rubbed them against some 80-grit sand paper and "rinsed" them with carburetor clear. Helped quite a bit. At the end of the day, cheap mechanical brakes are still cheap. If you still have problems after cleaning, I'd look at some decent quality mechanical brakes. BB5 (casual hills) or BB7 (if steep hills)
    Reputation: Straz85's Avatar
    Most bikes can use either rim brakes or disc brakes, not both. This is due to both the lack of mounts for both types of brakes on the frame as well as the wheels only being able to use one type.
    Wierdo
    Dec 2005
    The pads on mechanical disc brakes have to be adjusted on a regular basis to maintain good stopping power. That's likely why they work when you have them adjusted and stop working two weeks later. Have your shop show you how to adjust them. It's very easy.
  1. Replies: 1
    Last Post: 10-23-2013, 07:04 AM
  2. Replies: 11
    Last Post: 10-06-2013, 10:47 AM
  3. New brakes or swap out ????!!!!???!!!
    By Masneri in forum Brake Time
    Last Post: 08-24-2013, 11:26 PM
  4. Keep XX brakes or swap for Hope X2s?
    By E46_M3 in forum Brake Time
    Last Post: 02-09-2013, 08:02 PM
  5. Remove shock/linkage to swap brakes on bottlerocket?
    By jojotherider in forum Transition Bikes
    Last Post: 09-16-2012, 11:45 PM
