Bikes Similar to GF Montare and Cannondale Bad Boy?
9K views 15 replies 6 participants last post by  marchone
#1 ·
I'm considering an 'all around' bike to use for commuting, riding with the kids and toying around. I currently have a nice road bike that I ride often and an older mountain bike that gets little use. I want something in between the two and have been considering the Montare and Bad Boy.
Any thoughts on these two as well as recommendations for other bikes I should put on my list. Budget is around the $1300 that the Bad Boy will cost. Would like a bike with disc brakes and a front shock. Not interested in an internally geared rear end or single speed.
Thanks in advance.
#3 ·
New mountain bike, and some slick, inverted tread tires or racing tires - whatever works for the amount of pavement vs. dirt you ride. If you really want the 700C wheels, either get a 29er or get a 26" bike and a set of road wheels for it. 26" bikes don't fit especially big road tires, although how big is going to depend on the frame. I think a 29er with skinny road tires is a little wrong, in a similar way to a 26" bike with really little slicks. (Not that I wouldn't do it, of course.)
#4 ·
Sounds like you're drawn to the Montare and Bad Boy because of their flat black paint schemes.
I would spend $760 on the Trek Utopia and then put about $300 into upgrading the components. The components on the Montare and Utopia are both equally crappy and the frames are the same.
Only real difference between the two is HYDRO brakes vs MECH brakes and they are both very bad quality ones at that.
I ride a Utopia to work 5 days a week (7 mi one way), all paved and I could not be happier.
When I was looking at bikes I came down to the Montare/Utopia vs Bad Boy as well and picked the Trek after riding them. Just liked the way it felt better and because the Cannondale Dealer around only wants to help you if you are buying a $4000 road bike.
#8 ·
Thanks. I'd probably upgrade brakes on a Montare but now I'm looking at gear hubs instead of derailleurs. Shimano Alfine, not Rohloff Speedhub. Have to price a build out on a Karate Monkey and see how it compares. If I do that I just increased my budget from under a thou to under two.:madman:
#9 ·
How do you want to use this bike?
It's very easy to overspend trying to build the perfect/ultimate/whatever commuter. While internal hubs are appealing to me, too, I feel like the hardtail MTB and light touring categories really encompass most people's needs already.
Keep in mind also that complete bikes are almost always more cost-effective than building.
#11 ·
New York City commuting and transportation. Rough streets, potholes, cobblestones, curb jumping. No trails but plenty of dirt.
I want something reliable with less maintenance than chains and derailleurs will demand. I know that a build will be pricier even if I assemble it but I'm not likely to. It's all down to cost and the will to compromise.
#10 ·
I have not built a bike or done any major modifications on any bikes.
My guess is that it's kind of like building a computer. Most of the time it's not as cost effective as buying one off the shelf or even customizing one from Dell. In the end, it's a hobby and you feel good about building something. That's what it seems like at least. Well with bike, you need more (specialized) tools. A computer can usually be assembled with a only a flat head and Philips screwdriver.
#12 ·
I am loving my Marin Point Reyes for San Francisco commuting. I'm not familiar with NYC terrain, but here it's hills every way I look. I did look at IGH, but found the gearing didn't get low enough. About 1/2 mi of my commute is done in 26-32, about 22 gear inches, and that's the only part of my commute where I get sweaty. No way to avoid it since my office at the top of said hill.
I ride pretty much exclusively on pavement. Some of it is in pretty bad shape. One road I use in Golden Gate Park is seldom used by cars so it's probably not a high priority to fix, but the lack of cars is what makes it so attractive for riding. I guess it's kind of like riding through Central Park, but GGP is larger.
#13 ·
I remember doing that.
skankbike 001 by Andrew183, on Flickr
This was an intermediate form for this bike. I bought it as a 10-speed for under $200. It wasn't worth that, but I didn't have a lot of time on my hands, and figured paying a little extra not to deal with Craig's List was worth it.
Mechanically, it wasn't brilliant. But I started throwing things out, and once I'd replaced the pictured freewheel with a BMX driver, I had a reliable bike. Geared drivetrains weigh a ton! It was a lot lighter, and had much snappier acceleration too.
If you're ever going to have to lock your bike outside, definitely knock a zero off your price. And, rough streets, pot holes, cobbles, curbs, and road bikes have all existed since long before there were nicely paved, asphalt streets. Something with a little clearance for a 28mm tire would be good for a smoother ride.
If you decide you don't really need a bunch of gear ratios to ride NY (you don't, IME,) there are a lot of off-the-shelf solutions. I'd be looking at a catalog bike from Performance, or one from bikesdirect.com. But I've been riding for a while. Fit is really important, and if you don't have a reference to get you there, buying local has the advantage.
#15 ·
Well, I found a basically new 2011 Montare on Craigslist which was advertised as a Large and at a great price. However, upon getting it home I noticed it was an XL (21") which is slightly large for me. I sold the Montare about two weeks ago and made $100 on it. Now I'm leaning to a 2012 Bad Boy which should be in the LBS the middle of next month. I'll probably upgrade components at some point as I can never leave well enough alone but there's still time to select 'the' bike. Currently, the Bad Boy is on the top of the list.
#16 ·
I considered the Bad Boy as well till I decided to stay away from derailleurs. This will be my first bike in more than a decade and I always loathed their trickiness. I'm a low maintenance kind of guy.
I just posted a question in the Beginner's Forum about forkends. Please take a look.
