Best gearing for converted train lines, paved trails- Mtbr.com
Results 1 to 10 of 10
    Reputation: iKona40's Avatar
    I've got an old MTB circa 1993 that I'm considering converting to a paved trail, vacation, commuter type...thing.
    I'm interested in going the 1 x 9 route.
    I currently ride a 27 speed mtb and a 32 x 20 SS 29er mtb.
    I've found with the 29er, I don't have the need for so many gears.
    Would a 38t chainring up front with 9 gears in the rear suffice for mostly flat, paved, or crushed limestone trails?
    Thanks for any opinions!
    weirdo
    Reputation: rodar y rodar's Avatar
    You can use a gear calculator to compare your current gearing to just about any combo imaginable.
    http://www.sheldonbrown.com/gears/
    Your commute runs on rail trails? You dog!
    Recalculating....
    No-Brakes Cougar
    Reputation: Gary the No-Trash Cougar's Avatar
    That would probably be more than sufficient gearing. The only thing to keep in mind is whether your old rear hub is compatible with a newer 9-speed cassette (which it likely isn't) then there's your derailleur, etc.... Maybe consider a 1x7 or even a 2x7 set-up?
    R.I.P. Ronnie James Dio ~ July 10, 1942 May 16, 2010
    I'm actually going to go with new wheels and hubs, as well as new rear derailleur so hopefully all will be good.
    When I get the bike in the shop, the first question I'm going to ask is, what can stay, what must go, what are my options...1X9, 1x7, 2x7 etc.
    Should be fun.
    I don't intend to spend a lot, won't be something to ooh and aah over, but should be fun nonetheless.
    Thanks again for the info.
    Quote Originally Posted by Gary the No-Trash Cougar
    Ovaries on the Outside
    Reputation: umarth's Avatar
    For commuting, I'm not a huge fan of gears. Saying that, my current commuter is a 1x4. Sora rear, dura ace friction shifter converted to flat bar shifter with Paul's component.
    One is all you need. Four more than suffices.
    enjoys skidding
    Reputation: jasevr4's Avatar
    Feb 2005
    I ride what sounds like a very similar commute on my 29er with skinny tires (37c's.. probably makes it a 28er).
    I use a 32/14T ratio. It's probably a bit overgeared so you might be better off with a 15T or if you're a bit weak in the knees and in no rush maybe try a 16T.
    No-Brakes Cougar
    Quote Originally Posted by iKona40
    Should be fun.
    Don't forget a new shifter, too. Sounds like you might be spending more than you're anticipating.
    Should be fun.
    Old MTB means 26 inch wheels trains and paved paths mean flat, I would go 48 teeth on the front.
    Ain't that always the way...
    Bedwards Of The West
    Oct 2007
    We have a 'rail trail' near me, and I have taken my cyclocross commuter on it a few times. Biggest grade is something like 2% it's not paved, but well maintained dirt/gravel... I have a road double crankset up front, but no front D...I'm always on the big ring (50 tooth), and a mtb 8 speed out back. I haven't wished for more or less with that set-up. I think you'll spin out your highest gear if you go less than 48 or so up front.
    (no excuse for that either)
