29er tube?
Printable View
  • 03-17-2015
    vassock
    29er tube?
    What tubes are compatible with a Gravity G29? Will any 29 inch tube do? What are some cheap purchase options if I can wait?
  • 03-17-2015
    TenSpeed
    Any 29er tube will do. Check with your LBS, sometimes you can get a discount if you buy in bulk. One shop here does buy 2, get the 3rd half price.
  • 03-18-2015
    formula4speed
    Yep, any 29er tube will be fine. Just make sure you get the right valve type, presta or schrader.
  • 03-18-2015
    LyNx
    You could actually use a 26" tube in a pinch, only thing you have to look out for is to use the right size/width, so if you've got 2.2" tyres, you don't want to use a tube for 1.5" tyres, as they just don't stretch that way much.
  • 03-18-2015
    jrm
    ive always used 26" tubes on my 29ers but use 700c specific tubes if im running 700c tires.
  • 03-18-2015
    jeffscott
    i HAVE USED 1.5 INCH TUBES IN 2.35 INCH TIRES WITHOUT A PROBLEM.
  • 03-18-2015
    LyNx
    OH WELL, GUESS YOU WERE LUCKY, I HAVE TOO, BUT IF YOU DON"T WANT TO CHANCE IT, YOU USE THE RIGHT SIZE!
    BTW, why are we shouting?
  • 03-18-2015
    jeffscott
    aLL TUBES GET THINNER AS THEY STRETCH, AND THAT CAUSES THEM TO BE A LITTLE WEAKER.....BUT NOT MUCH.
    mAYBE YOU CAN GUESS WHY i AM SHOUTING.
  • 03-18-2015
    vassock
    Will this fit my Gravity G29?
    For Bike Bicycles Schrader Inner Tube 29 x 1 95 2 125 48mm | eBay
    Save up to 60% off new Mountain Bikes - MTB - Gravity 29 SS Single Speed 29er Mountain Bikes
    What does the 48mm mean?
  • 03-18-2015
    jp08865
    48mm is the length of the valve stem.
  • 03-19-2015
    Rustedthrough
    If you have the Schrader valve (as shown on the Gravity page), that tube should work.
