Does Anyone Recognize this Bike?- Mtbr.com
Results 1 to 7 of 7
    Dec 2015
    My coach gave this bike to me and told me that it was a Yeti ARC from when Yeti and Schwinn had the same frames. I've been told over and over that it isn't a Yeti and so I decided to pull some of the tape off of the seat tube and found it has a Kona 6061 aluminum decal underneath. I emailed Kona but they said it isn't a Kona and the factory that usually builds bikes with similar serial numbers had no record of this bike. Anybody recognize this frame or see any others that look similar to it? I don't know if the paint is original either so I'm pretty much clueless. Here is where I posted all of the pictures.
    https://drive.google.com/open?id=0Bw...0tIenp6RE5JQlU
    Schipperkes are cool.
    Reputation: banks's Avatar
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    Back in the day when they were doing things together there were no disc brakes-or very few. Not sure what that is. It looks familiar, but...... Good luck
    Reputation: sbsbiker's Avatar
    Post to the Vintage,classic, retro...they know of old bikes.
    Dec 2015
    It looks like a 2002 Kona Caldera. The only thing is that the Klassic Kona webiste says that the frame was made of 7005 aluminum but this one shows that it is made of 6061 Aluminum.
    Quote Originally Posted by sbsbiker View Post
    He already did, along with many other forums.
    http://forums.mtbr.com/vintage-retro...ke-997769.html
    pusher of buttons
    Reputation: bikephan's Avatar
    I would start with matching your der hanger to one on wheels manu. Then that will narrow your options and just google said images of frames. There are some keys you are looking for, cable routing on top of top tube. unique dropouts for rear of frame, 1 1/8 head tube, gusset on downtube, rear der cable running under the seat stay etc.
    WTF
  1. Anyone recognize this bike / frame?
    By Chad_M in forum All Mountain
    Last Post: 10-31-2013, 06:23 PM
  2. Do you recognize this car?
    By Bagwhan in forum Colorado - Front Range
    Last Post: 09-14-2013, 11:32 PM
