Results 1 to 10 of 10
    Reputation: JLampitt's Avatar
    Winter Riding w/ BB7's
    Anyone have any ideas how to keep the rear BB7 caliper on my Prophet from freezing up during winter riding... when it's really cold/riding in the snow? The front has no problems. I've changed the cable housing and cables. It seems an issue with the caliper. Aside from winter riding, there are no problems with the BB7's. Love 'em.
    t.i.t.s.ceo/FR amoeba rep
    Reputation: PBR me!'s Avatar
    Maybe they have a glaze on them, try wiping them down with some denatured alchohol? When mine squeal or get dirty that usually does the trick.
    edit: thought you meant the rotors, check that spring that holds the pads may have got dislodged, but if they work in warmer temps??
    I'm a cowboy on a steel horse i ride!
    the blog
    skillz to pay billz
    Reputation: nOOby's Avatar
    brake more often = heat
    Stand back
    Reputation: dbabuser's Avatar
    I've never had that issue w/ my bb7's, in 7 yrs of running them and lots of snow days. Your caliper might need disassembled/ cleaned.
    Golden Bike Park
    Golden Connector Trails need your support!
    hehe ...you said "member"
    Reputation: jake7's Avatar
    is it hard to engage the brake, or is it not releasing when you let go? both?
    “Me fail english? Thats unpossible.” - Matt Groening
    I remembered seeing this on icebike some time ago:
    [URL="http://www.icebike.org/Equipment/testedonice.htm"/URL]
    Scroll down to the Parsons Bo Peep Ammonia. The reviewer used it on iced up brake pads, but it should work on disc calipers. I never tried this, so take it with a sizable grain of salt.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    ...Use it...?
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    Sorry for the late reply.
    The issue seems to be with the caliper release. I can engage the brake (although when it's frozen, it's harder to engage) but then the caliper won't release. It's like they're stuck in the engaged position... almost like there's not enough spring tension.
    I've dissassembled it and cleaned it several times... even going so far as to lube it with some Finish Line lube that is designed to be used in cold weather.
    There's no problem stopping... once those pads engage the rotor, I usually come skidding to a stop because I can't feather my braking action.
    BB7s have an adjustable spring tension for the release. There's a small screw on the body towards the back whith which you can increase the spring tension.
    Quote Originally Posted by blinker
    Yeah... tried that....
    Maybe I should just pee on it to defrost it.
    Not much use for brakes when riding Waterton in the snow, but it get's a little dicey on some other winter fav's that have a slightly steeper pitch.
