SHIMANO CN-7701 Chain
Printable View
  • 10-18-2011
    mestapho
    Is not Clyde friendly.
    6'1" 250 lbs and have broken this chain twice now on climbs.
    It only has about 25 miles on it.
    Have a Connex in the mail, hopefully it lives up to their test results.
    Putting it out there so someone
    else doesn't waste their money.
  • 10-19-2011
    rdickens48
    I have been running this chain for a while now. I weigh between 215 and 220, sometimes a little heavier. I have not broken one of these chains yet. I even shift under load sometimes on climbs.
  • 10-19-2011
    mtnbiker72
    I used to use those before switching to KMC X series chains (and BTW never broke a CN-7701)...they come with a quick link, are very strong, shift well with SRAM and Shimano cassettes and chainrings, and usually cost quite a bit less.
    KMC X9.99 9 Speed Chain at JensonUSA.com
  • 10-19-2011
    mestapho
    Maybe I just got a lemon.
  • 10-19-2011
    JWill
    I'm currently riding at approx 255lbs, down from 295, I rode this shimano chain for the first few months of mountain biking and had the same issues. Went through a couple and then tired KMC, and had great results with much less stretch over time. However, I think what did it the most was being more conscious of shifting under load, mashing the pedals while standing up, and other types of sloppy riding/pedaling. This improved everything and made the chain and cassettes last a whole lot longer. Since all that, I've completely changed my drivetrain to a full Shimano SLX dyna-sys 10spd and am running a Shimano chain as well, with zero problems at all for months now.
  • 10-19-2011
    mestapho
    The first time I broke it was definitely due to sloppy shifting and trying to overcome it by standing on the front pedal. The second time was not though. I was just about to make it up a climb I'd never made it up before and SNAP! Sucked big time.
  • 10-19-2011
    mopartodd
    It could have still been damaged from the first incident. I've run these chains for years at 250 lbs and never had a problem...but it certainly isn't unheard of for big guys.
  • 10-19-2011
    mestapho
    Yeah, that's definitely a possibility.
  • 10-19-2011
    clydecrash
    I have never broken one either (was up to almost 300lbs at one time), but I am an easy shifter and a spinner (when I can spin). I haven't broken a SRAM chain either except a few times when I shifted very poorly. That all said, I have a couple of SRAM crosssteps waiting when I replace the next chain.
