Yakima SLR Bike Mount - 9mm info????- Mtbr.com
Results 1 to 3 of 3
    Muhuhahaha
    Reputation: Demonsmasher's Avatar
    Dose annyone know anything about is bike carrier?
    J_S
    J_S is offline
    It's just a fork-mount rack with a long tray. Yakima changed the skewer size from something smaller than 9mm to 9mm around 1992?, and advertised the change for a year or two. SRL is short roof line, meaning you needed a long tray. It will fit your round bars and hold your fork. No lock, as I recall.
    Muhuhahaha
    DO you know if forks with disk breaks will fit this or will I need to cut the tray alittle to fit it? My plan is to use these and run the bars across the top of my pickup bed and put my bikes on these.
