xterra owners>>>- Mtbr.com
Results 1 to 2 of 2
    xterra owners>>>
    I have an 07 Xterra with the Yakima LowRider Max w/Claw 2 and the Sprocket Rocket rack. I still have a bunch of whistling and howling even with the factory fairing on the roof. My question to you is that would a second fairing mounted to the cross bars make a difference as far as howling and whistling goes? How stupid would it look with two fairings on the roof?
    Reputation: longman's Avatar
    slide the rack back as far as it will go without hitting the tailgate(the windwill go over the top of the bar instead of around it). if that doesn't work yakima makes the 'windjammer' for $17 instead of another fairing, it doesn't always work but it's worth a try, put it in the center of the front crossbar and play around with the angle until the noise stops or reduces.
