Wheel On options?- Mtbr.com
    Wheel On options?
    Anyone know of any wheel on (front wheel carrier on the roof) other than Thule? I think the Thule won't work with the Nissan Xterra factory cross bars. Did a google search, but didn't have any luck. Thanks
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    the thule wheel on will work on the nissan xbars, but you will need longer bolts.
    the thule xadapt 3 should alleviate the problem with the oversized crossbars.
    the wheel on is the same foundation as the thule stacker kayak rack - with just a different top, and thule calls for this xadapt kit to be used with the stacker.
    yakima makes a few and i own 3 but i like the thule big mouth more. they are easier on the frame and easier to setup they also have a wider opening for the downtube.
    Thanks Cracks, I'll look at those.
