What size is my hitch? 1.67"?- Mtbr.com
Results 1 to 14 of 14
    /|\ is offline
    I just measured the hitch that has been on my car since I got it used a few years ago and it measured 1.67". I've seen plenty of 1.25" and 2" racks and adapters, but no other size. Has anyone seen adapters for this size?
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    i would venture to say that your measurement is coming in as a 1.25"....are you measuring the inside opening?
    /|\ is offline
    I'm measuring 1.67" square on the inside with a caliper.
    Its a 1.67" hitch.
    /|\ is offline
    OK, so do you know if they make adapters for a 1.25" bike rack?
    Are you measuring on the diagonal or horizontal?
    /|\ is offline
    horizontal
    Ride Responsibly
    Reputation: LWright's Avatar
    Never heard of a hitch receiver that size (1.67"). Maybe it is home-made?
    in all seriousness that is very strange. i second the possibly homemade??
    you might want to look into getting a new hitch.
    Maestro
    Reese Hitch
    In the late 70's, early 80's Reese made a line of class 2 (3500#) mini receivers for cars. I used to see them in the JC Whitney catalog. They used 1-5/8" square drawbar. They have been out of production for at least 25 years.
    My only suggestion is finding a welding shop to make you a drawbar or replace the hitch.
    What about shims? a thin "[" shaped shim.
    /|\ is offline
    Wow, thanks a lot. I'm kind of surprised my mid 90's car has a hitch that old, but that definitely makes sense. I think I might be able to have the standard 2" to 1.25" adapters machined down to size, hopefully that works.
    Maestro
    Shims yes
    Quote Originally Posted by the-one1
    You could use 3/16" flatstock for shims. You could tack weld them into the receiver opening or to the drawbar od the rack. I believe the mini receivers used a 1/2" drawbar pin, which is the same as the 1-1/4 drawbars used today.
    Quote Originally Posted by /|\
    Machining down an adapter would probably weaken it a lot. IMO it would be better to just buy a modern hitch.
