What are the best bike rack options for full-size pickup bed?- Mtbr.com
Results 1 to 20 of 20
    I use the 1UPUSA rack on my Jeep and 4Runner but I just picked up a standard-bed GMC 2500 HD (diesel). It is long enough to where I do not want to use a hitch rack. Plus, I do tow a camper at times and carry a bike or two. What rack options are you guys finding are the best? I'm thinking that Yakima and Thule prob have the best options. I have supported Rockymounts (local-ish to me) but not anymore. Their quality just sucks on all the racks I had and have.
    I figure that keeping the bike in the bed would be the best option. I have seen a few fork-mount options but some real-world feedback would be good. Also, the methods of securing the rack to the bed- that would be useful information. I do have a factory bedliner and also don't want to drill anything. Thanks!What are the best bike rack options for full-size pickup bed?-denali2018-copy.jpg
    Reputation: k2rider1964's Avatar
    I'd personally throw them over the tailgate. I would do pretty much anything to avoid taking the front wheel off. YMMV. You might want to check out Pipeline racks Truck Bike Rack, Pickup Truck Bike Racks by Pipeline Racks
    2019 Ibis Ripmo
    2019 Yeti SB5 (Sold)
    2018 Intense Tracer (Sold to son)
    2017 Intense Primer
    i like rocks
    Reputation: euroford's Avatar
    badarse diesel trucks should have bikes on the tailgate.
    Tim M Hovey
    Nukeproof Mega 290
    1950 CJ3a
    1999 BMW 540i
    1999 F350 PSD
    Jun 2017
    I have a Ram 3500 and use Thule insta gaters. They work well. I didnít want to have to install and remove a one up or similar each time I went to ride...Iím already long enough as is, plus I tow a toy hauler and or atv trailer many times per year and obviously a hitch mount wouldnít be convenient.
    Sent from my iPhone using Tapatalk Pro
    2017 Ibis Ripley LS Factory X01
    Pipeline racks does have some interesting options. I like that Thule Insta Gater as well. I did see that one earlier. Need to check these out in some detail. I also don't want anything hanging past the tailgate. The truck is long enough to begin with. With the bikes in the bed, I can tow my camper without worrying about trying to rig them between the two. I also don't want to wedge the bike on the tailgate.
    Reputation: Flamingtaco's Avatar
    Mar 2012
    If you've got any tie-downs on the floor, check to see if the have are secured with captured nuts. If they are, you can bolt bars (that run across the bed) or plates that can be used to mount bike trays.
    I will suffer no butt-hurt fools!
    Reputation: kevin267's Avatar
    Mar 2011
    1 bike I lay in down on it's side in the bed, 2+ bikes tailgate pad and hang them over tailgate. Never felt like I needed a rack, but I think about a hitch mounted rack, then could carry bikes and have the full bed (with canopy on) available.
    I think I need to go in another direction since I do want a bed cover. There are a couple of companies that make retractable and tilt-up bed covers or tonneau covers that have grooves to attach cross bars. I think I will go this route and use Yakima Jetstream aero bars plus their new bike rack...the Highroad.
    I actually prefer the water-tightness and simplicity of the tilt-up covers but with the retractable covers, the contents in the bed can be easily accessed without taking off the bikes. The Pace Edwards Ultragroove series looks decent but only 2-3 companies do this so my selection is limited. Of course, this is a much more expensive option but I can keep stuff in the bed and people cannot see the contents or easily lift the contents in case I step somewhere for a meal or whatever. The truck is normally garaged but I'm more concerned about trips to Moab, Fruita, etc.
    May 2012
    2016 GMC 2500 HD. I use the 1Up roof rack trays for the bikes and had a local fabricator make the bars. The bars are mounted to o-track so they can be moved fore and aft or removed.
    Sent from my iPad using Tapatalk Pro
    Aug 2013
    Another vote for instagaters. I have 2 for my F150. Secures bikes quickly and easily removed when not needed. Check Craiglist, they pop up once in awhile.
    Apr 2016
    I pretty much have a soft cover on my bed at all times. I went with Summit Racks gutters mounts. This allows you to use any bars with gutter mounts you want. I'm using Thule towers and bars and just added my rack on top of that. You would need to make sure your cover mounts in a way to let this work I think.
    Reputation: armii's Avatar
    Jan 2016
    I have a roll top locking cover. I pull the front tires off and load two bikes on their sides, with a moving pad between them, and I am able to close the roll top.
    Reputation: zgxtreme's Avatar
    Third vote for the Instagater... used one in my Super Duty before selling the truck and it worked really well. Will use it on my next truck if the bed is long enough.
    Dec 2017
    I use a hitch rack with my diesel pickup, SUV, and even her Prius! I also have fork mounts that I put on a 2x4 and use in the bed of the pickup when the camper isn't in it, but the hitch rack is so much easier, I see no point in switching!
    I like that GMC setup above. I'm going with something a bit similar but a retractable bed cover by Pace Edwards with the rails already installed...the Ultragroove Metal model. Yakima 70" Jetstream bars in black, Skyline towers with landing pads, and Yakima Highroad bike racks. I'll try to post a pic when done, and I hope to get this done by next weekend. Then...Fruita!!
    Jan 2017
    I like the RIDE88 rack. It's not made for cars, it's made for trucks and it's integrated and dialed. https://www.ride88.com/
    What are the best bike rack options for full-size pickup bed?-quad-truck.jpg
    What are the best bike rack options for full-size pickup bed?-img_1318.jpghttps://youtu.be/m2nlN_FTZ-s
    Quote Originally Posted by Design88 View Post
Name:	Quad truck.jpg
    That's a well thought out design, and fine looking bike rack. Congratulations.
    2019 Rocky Mountain Altitude C70 Custom
    2018 Pivot Mach 5.5 Custom
    2018 Orange Alpine 6 Custom
    2017 Knolly Warden Custom
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Yes, hopefully you would like it
    If I didn't have a roll top on mine for work, is definitely consider something like that.
    Jan 2017
    Quote Originally Posted by Shark View Post
    The system does work for tonneau covers by a quick release lowering the top arm. Also there is a quick release to remove rack rack out of the bed.What are the best bike rack options for full-size pickup bed?-dsc_4044.jpg
    20% off deal running right now at Ride88.com. Mention MTBR and I'll step up more.
    The system does work for tonneau covers by a quick release lowering the top arm. Also there is a quick release to remove rack rack out of the bed.]
    Is it just the tension bar that holds that rack in the truck bed? Any other means besides the bar hold the rack in for rougher bumpier roads?
    XC, Road, XXC, Endurance, Mtn, All-Mtn, Cross, Gravel, just go have fun on 2 wheels!
  1. New Bike Rack for Gmc Trucks
    By JJ59 in forum Cars and Bike Racks
    Last Post: 02-04-2015, 10:10 AM
  2. Replies: 16
    Last Post: 08-24-2013, 01:51 PM
  3. Hitch rack on a full sized pickup?
    By KevinGT in forum Cars and Bike Racks
    Last Post: 04-22-2013, 03:53 PM
  4. new bike rack for nissan trucks
    By skylinedrive in forum Cars and Bike Racks
    Last Post: 05-24-2012, 02:32 PM
  5. ANOTHER homemade(ish) bike rack! (open bed trucks)
    By hazardousmtb in forum Cars and Bike Racks
    Last Post: 04-30-2012, 06:02 PM
Members who have read this thread: 84
