Trunk Racks and Bikes with cables on bottom top tube- Mtbr.com
    Reputation: RyanJC's Avatar
    New question here. Trunk Racks and Bikes with cables on bottom top tube
    I have a Giant NRS that has its cables running below the top tube. I'm worried that if I transport my bike on the Saris Bones rack I have that it will damage/stretch the cables out. Should I be worried? Are there other solutions other than just padding the area the bike will rest on the rack?
    Reputation: golivar's Avatar
    Oct 2007
    My bike has exposed brake and drlr cables on the underside of the top tube, and I've been using an Allen trunk rack for the past 3 months; the top tube sits on top of the cables when it's on the rack, but I haven't had any problems. I think as long as you make sure the bike is secure and doesn't sway around on the rack, it should be fine. Hope this helps.
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    they will rub and cause cable rub and/or scratch the frame eventually..try something like this: (crappy pic but u get the idea)
    http://www.mec.ca/Products/product_d...=1195480817244
    http://www.amazon.com/Allen-Tension-.../dp/B000ELSSZE
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
    less is more
    Reputation: venus1's Avatar
    I've cut an old inner tube & used a 2" section between frame & cable. Ain't pretty but works. I'm sure someone will come up with something to sell.
    Finesse is everything.
