Thule T2: Suspension fork/front brake line interface wear.- Mtbr.com
Results 1 to 6 of 6
    Rent this space for $
    Reputation: Oh My Sack!'s Avatar
    I can't imagine that I'm the only one experiencing this wear down from the front brake line support. So far my only attempt at reducing wear had been wrapping some gorilla tape around it. Has anyone come up with any creative ideas to curtail or eliminate the wear?
    Thule T2: Suspension fork/front brake line interface wear.-20181224_154906.jpg
    Mine is worn at that spot too. I thought about wrapping it with an old split tube.
    Quote Originally Posted by the-one1 View Post
    Not a bad idea. Perhaps a little resilient foam fill of the cavity created then wrapped with a tube. It may not cut as easy as the tape does on my temporary fix.
    Iíve been using a T2 for 7 tears, it touches there but I donít have wear like that. What tire width and fork are you using?
    I just recently saw an aftermarket brake line clamp/bolt to replace the factory one. Maybe not as sharp as what you have or you could file it down smoother.
    Foam pipe insulation with some heat shrink tubing over the top? Maybe some of that silicone tape that only sticks to itself?
    Reputation: JustMtnB44's Avatar
    When I had a Sidearm rack it never had any wear like that. Are you tightening the arm down enough? There should be no movement between the arm and the bike as that would cause wear; they should be locked together as one unit.
    Aug 2015
    The Kuat NV 1.0 would do the same thing On my Enduro.
  1. Did Canfield change the rear brake interface?
    By madamfunk in forum Canfield
    Last Post: 04-15-2016, 08:37 PM
  2. 2014 Element 999RSL creaking headset/fork interface
    By biking_dane in forum Rocky Mountain
    Last Post: 08-05-2014, 01:56 PM
  3. Thule Doubletrack Vs Thule T2
    By dills84 in forum Cars and Bike Racks
    Last Post: 05-01-2014, 08:53 AM
  4. Oversize hub interface with rigid fork?
    By JonathanGennick in forum Wheels and Tires
    Last Post: 03-05-2012, 08:58 AM
  5. stiffening a regular hub/fork interface
    By Crockpot2001 in forum 29er Bikes
    Last Post: 07-03-2008, 09:01 AM
Members who have read this thread: 24
