Thule T2 Assembly Warning- Mtbr.com
Results 1 to 10 of 10
    Reputation: troutbike's Avatar
    Others may have had this problem, but I didn't see it anywhere in my search. If you plan on buying a T2 be very careful when you install the wheel tray to the arm. The instructions say to tighten firmly, however they don't mention the repercussions of a half-turn too tight. I snapped the plastic stud right off the wheel tray. "Snug" might have been a better choice of words.
    This was my mistake though and I should have looked to see if the stud was all plastic before turning the wrench. I just wanted everyone to be aware if you are putting one together. Seems like a great rack.
    Quote Originally Posted by troutbike
    I was lucky, the shop I bought it from replaced the tray for free (they said this happens a lot). The T2 is well made, otherwise, but I think it's a big "miss" to not have metal inserts for the bolts/screws in the trays.
    I did exactly the same thing. Not a good design but I should have paid more attention too.
    GALATIANS 2:20
    I'm thinking of getting Thule rack. Is this plastic stud problem something you can retrofit with some metal equivalents from a Hardware store so as not to have to worry about this?
    God Bless
    Critter Cameraman
    Galatians 2:20*
    It is not something you have to worry about if you don't overtighten the bolt. I used it a couple time with only one bolt in it and it was completely solid. the bolts just pull the thing together. If you don't overtighten I don't think there is any chance of snapping it the way that the tray and stud sit in the groove on the other side.
    Reputation: the Inbred's Avatar
    odd, i've never seen this happen.
    Well, since they use a self-threading bolt, I initially used a socket set to tighten it. I found out the hard way it's better to use a flat head screwdriver, and gradually snug it tight.
    I do agree the instructions kind of suck, but I didn't have this problem. Better instructions would have brought assembly time down to a half hour instead of the embarrassingly long time I spent to make sure it was done right.
    Reputation: grawbass's Avatar
    Quote Originally Posted by Critter Cameraman
    If the trays are similar to the old ones, then yes. You can use the rectangular plates that come with U-bolts and a couple small carriage bolts. You might have to grind the rounded end of the carriage bolts flat though.
    Wanted: broken Titec 2 bolt seatpost, any size
    pedaller
    Reputation: Noelg's Avatar
    been there, done that!
    I did the same thing and I called Thule and they said they had never heard of this happening BUT they promptly sent me a new wheel tray (no charge).
    Still, I hate the design. They should have at least included a 4-inch bolt for the deeper hole in the tray instead of a 2-inch...
    I ended up drilling out the hole altogether and inserting a 4-inch bolt from the top and a nylon nut at the bottom. It worked like a charm and now I'm not depending on plastic threads to hold it together.
    "Nobody ever told me not to try" - Curious George Soundtrack by Jack Johnson
