Thule hitch mount rack- Mtbr.com
Results 1 to 5 of 5
    Aug 2010
    I have a 2-up hitch mount and want to use a locking botl on the reciever. The bolt I have doesn't fit through the threads in the Thule's mounting hole. Do you think it is ok to drill it out?
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    i would recommend getting a bolt that fits the thule bike rack instead. the thule stl2 is designed to be a locking hitch bolt for thule bike racks.
    Aug 2010
    Thanks for the product link. that is definitely the "right" choice. But wouldn't it be cheaper to drill out the threads and use the lock I already own? $50 is a lot for a lock, but I could easily spend that much on drill bits or labor at a trailer company... I think..... That's why I am asking... I already use the lock I have for my trailer hitch.
    code: mtbr2011
    if you drill out the threads and use just a locking hitchpin, then you'll have a bunch of play in the rack and it will wobble inside the hitch, eventually leading to metal fatigue and failure...
    better to use a bolt, rather than a pin. if you have a bolt already, you could re-tap the threads to match the thread pattern on your existing bolt.
    Aug 2010
    gotcha... good info.
