Securing SARIS Bones- Mtbr.com
Results 1 to 5 of 5
    How do you secure this rack (and bike) to your vehicle?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by discombobulated_conundrum
    So it does not fall off or against theft?
    mtbtires.com
    So sorry I didn 't make it clear. It's against theft, or at least discourage it.
    Reputation: Heat's Avatar
    Honestly I don't really think there is a way aside from just taking it off when not in use. I keep mine on my car all the time; I understand it's a risk I'm taking that someone can just come by and loosen the straps and walk away with the bike rack. (it's more of a concern when my bike is actually attached! )
    If you have a car alarm I suppose setting the sensitivity a little higher so if someone were to fiddle with the rack the alarm would go off?
    or you can secure a cable around the 'aluminum tube' of the rack to something underneath the car? I have a little tow loop under the bumper of my civic i could probably run a cable through.
    Dec 1998
    I run a cable through the central tube and lock it to the tie down loop under the bumper.
    Works well on my Civic.
    mtbtires.com
