Saris + mighty mounts=?- Mtbr.com
    Has anyone tried to use Yakima Mighty Mounts with Saris load bars?
    Need some new upright mounts and would like to keep my Saris load bars & fork mounts.
    CAMBr West
    Gives us a couple bucks and we'll give you some trails with sweet jumps and stuff.
    Reputation: JustMtnB44's Avatar
    I put Thule Sidearm carriers on my Saris load bars and that combo worked ok. If the Yakima attaches in a similar fashion it should work.
    Were you able to mount the Sidearm to the Saris bars without any adapters or did you use the mighty mounts?
    CAMBr West
    No adapters needed. The Sidearm just mounts with bolts that slide into the trays, then a plate goes under the load bar with nuts to secure it on. The stock bolts are just barely long enough for the thick Saris bars, but it does work.
