Saris + mighty mounts=?
Printable View
  • 04-02-2010
    Seanbike
    Has anyone tried to use Yakima Mighty Mounts with Saris load bars?
    Need some new upright mounts and would like to keep my Saris load bars & fork mounts.
  • 04-02-2010
    JustMtnB44
    I put Thule Sidearm carriers on my Saris load bars and that combo worked ok. If the Yakima attaches in a similar fashion it should work.
  • 04-02-2010
    Seanbike
    Were you able to mount the Sidearm to the Saris bars without any adapters or did you use the mighty mounts?
  • 04-05-2010
    JustMtnB44
    No adapters needed. The Sidearm just mounts with bolts that slide into the trays, then a plate goes under the load bar with nuts to secure it on. The stock bolts are just barely long enough for the thick Saris bars, but it does work.
