roof rack for 2006 Grand Cherokee?- Mtbr.com
Results 1 to 7 of 7
    Feb 2012
    what fits?
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    what's on the roof of your jeep? elevated side rails that go front to back?
    Feb 2012
    code: mtbr2011
    you could use the factory installed crossbars to attach up to 2 bikes directly to those crossbars, or you could bypass those crossbars and use a stronger, more versatile rack system, like the thule 45050. then you can attach bike mounts to that, but also have the ability to carry additional accessories at the same time.
    Feb 2012
    what do i need to attach the bikes to the Factory Installed Crossbars? i clicked the link, but doesn't have any specifics on which one fits the rack on my jeep? are they all universal? thanks!
    code: mtbr2011
    any of those bike racks will fit your jeep...fork mount or upright carrier.
    if you are ok taking your front wheel off, and fork mounting the bike, then i'd recommend the yakima forklift or the rocky mounts tierod.
    if you want to carry the bike with both wheels attached, then i would recommend the thule sidearm.
    in fact, i'd probably recommend this rack over the others, because it is least likely to stick back as far on the roof as the others which might create rear hatch interference.
    Feb 2012
    Thanks! ill look into those three in particular!
