rockymounts monorail front wheel release button issue/question- Mtbr.com
Results 1 to 3 of 3
    wondering if anyone else runs into this-
    I just got this rack, its been great. But yesterday when I went to release the front wheel hook/clamp thing, that blue release button just pressed in easy. The hook was ratcheted down tight, but the blue button had no resistance inside it like normal, I could just press it and nothing happened. I ended up deflating the front tire so I could get the wheel out. After this I was able to ratchet it down a little more and trigger the mechanism to click and release... if that makes sense.
    So now im nervous of getting it stuck on there, its happened again but im careful to notice and have been able to force it down another 'click' and the button was tight again.
    Is this just a normal quirk, maybe lubricating the ratchet rail part could help?
    May 2019
    I usually push the hook down an extra click, especially when it's an inch or so in front of the bike's fender. I usually have to push or squeeze pretty hard on the button to get it to release.
    So, are you sure you pushed it far/hard enough?
    I don't know about lubricating the ratchet, but occasionally I've been having some binding along the slide at maximum hook extension, but I'm not going to lube it. I figure it'll just attract too much dirt, and the dirt would make it worse. A little hit on the hook loosens it enough so it starts sliding easily enough.
    I've noticed mine doing that with larger knobbier tires. After it clicks when down, I just push up to check it (without pushing the blue button). It will click in to a natural spot, then the blue button has the proper tension. I think there is just a little bit of tolerance there.
  1. Thule T2 classic vs Rockymounts Monorail for a camry
    By jbourne84 in forum Cars and Bike Racks
    Last Post: 05-15-2019, 11:27 AM
  2. RockyMounts Monorail Solo
    By Dr Evil in forum Cars and Bike Racks
    Last Post: 11-20-2018, 07:52 PM
  3. Button, Button, Who's got the Button?
    By MOJO K in forum Off Camber (off topic)
    Last Post: 01-28-2018, 09:46 PM
  4. Maxxis Monorail 26er tire about 50% off
    By danK in forum Where are the Best Deals?
    Last Post: 10-23-2011, 08:51 PM
  5. Maxxis Monorail vs Crossmark advice
    By Tayancycles in forum Wheels and Tires
    Last Post: 05-02-2011, 10:52 AM
Members who have read this thread: 17
