REVIEW: 2x2 Cycles Motorcycle Bike Rack- Mtbr.com
Results 1 to 18 of 18
    Trail Cubist
    Reputation: SWriverstone's Avatar
    I've been motorcycling for longer than I've been mountain biking...so it was pretty natural for me to want to find a way to carry a bike on my motorcycle (Suzuki V-Strom 650). I first researched options last year and found the 2x2 Cycles Motorcycle Bike Rack...which currently seems to be the only commercially sold rack out there.
    The cost of this rack is $308 shipped, so at first I thought I could do better building my own. I first picked up a cheap fork clamp and some 2x4's and tried to jury-rig something (basically bolting the fork clamp to a 2x4, then bolting the 2x4 to my factory motorcycle rack.) That might have worked, but I found it difficult to accommodate bikes of different sizes (e.g. my road bike and mountain bike), so I bagged that.
    Then I picked up a Yakima Copperhead mount, which is a basic roof-mounting tray with a fork block at the front. The long tray would accommodate any bike...but then I found it difficult to mount it in a way I trusted (I'm not a welder and didn't feel like learning.)
    So in the end, I said "Screw it" and bought one of the 2x2 Cycles racks...good move---I should have done it from the start!
    The 2x2 rack is pretty bombproof and almost over-engineered. The whole thing is made of pretty heavy powder-coated steel, and the thing is heavy. I didn't weigh it, but I'm guessing it's at least 20lbs. The fork clamp is really beefy---far sturdier than any fork clamp I've seen on a Yakima or Thule rack.
    Mounting the rack might have been straightforward but turned into somewhat of a major production---this is because I wanted to be able to use my Givi topcase as well as the rack, so I had to figure out a way to bolt the topcase mounting plate over the bike rack. The ideal solution turned out to be some solid aluminum standoffs threaded at both ends (I had 'em laying around from an old project).
    The 2x2 Cycles rack came with an LED running/brake light bar. At first I didn't think this was necessary, but I quickly realized that when a bike is mounted on the rack, it obscures my stock tail/brake light from several angles. Motorcycling is dangerous enough already, so this wouldn't do. I mounted the LED bar lower down, just below my license plate. (This was a pain as I had to remove the rear fender to get to the wiring.)
    Anyway, once I got it all mounted up, it felt bombproof---I probably could lift the motorcycle by the bike rack. This afternoon I took it for the first test rides. Here are some pics of the rack (the silver posts are the ones I mounted to attach the topcase plate to)...
    Note how the fork clamp has a secondary bar with a hole in it so you can lock the bike to the rack with a padlock---nice feature.
    The rear of the rack is a length-adjustable piece of square steel channel with a "cup" which holds a pedal crank:
    The slotted piece to the right of the cup is what holds your front tire (via the quick release clamp)...and the dangling quick-release clamp (above) is what keeps your pedal crank securely in the cup.
    Here's what my GF HiFi Pro 29er looks like all mounted up on my V-Strom:
    As you can see, the bike is cantilevered far out from the rear of the motorcycle. At a glance, this looks odd and scary...but once I clamped the bike into the rack, it didn't budge (I could shake the whole motorcycle around by grabbing the bike frame.) The rack also comes with a nice little yellow nylon "warning" streamer with a snap link for the rear wheel.
    I was a little bummed that I couldn't get my mountain bike on the rack with the topcase plate mounted---this is because the fork clamp isn't high enough to give the front brake calipers adequate clearance over the plate. Not a huge deal---I just took the topcase plate off. (FYI, a road bike fits fine with the topcase plate---since road bikes don't have all that junk hanging off the front fork, LOL.)
    Here's a couple closeups of the forks in the clamp. The rack also comes with a safety strap that the manufacturer recommends using. It's really a common-sense backup kinda thing, as I'm 100% certain the fork clamp and rack hold the bike very securely without the strap---but since it only takes a few seconds to put the strap on, I use it anyway. (The strap also takes some of the load off your factory motorcycle rack and distributes it to the motorcycle frame.)
    In the shots below, you can see the pedal crank in the cup and how the quick-release clamp holds it in place...as well as how your front tire slots into the rack and is held by the quick release clamp. This seemed questionable to me (holding the front tire by one side)...but in use, the tire was rock-solid and didn't waggle around at all.
    When I first started riding the motorcycle with the bike mounted, it felt a bit odd. I'm sure this wasn't a weight issue, but more an issue of the weight being cantilevered so far out the back. I wasn't worried though---I ride 2-up with my wife all the time, so the 50lbs (give or take) of the rack and my bike was nowhere close to the weight of a passenger.
    I rode a bit timidly at first, constantly checking my mirrors to see how the bike was doing. I rode about 15 miles to the local state forest (Coopers Rock State Forest outside Morgantown, WV), and most of that was on the interstate at 80mph. It was windy today (gusts up to 25mph), and I didn't feel a thing (in other words, wind isn't an issue---bikes make poor sails).
    For the whole ride to/from the state forest, the bike was rock-solid. No waggling or swaying of any kind. There is a very small amount of up/down flex in the rack arm, but it's barely noticeable (even going over bumps) and it's probably good from an energy absorption standpoint.
    I've heard some people say they wouldn't like doing this because they'd have to lug their bicycling gear with them, change into it, deal with the motorcycling gear, etc. That wasn't a problem at all for me---I have Givi sidecases, which are plenty big enough to hold my riding shoes, helmet, and Camelbak...
    I just wore my riding shorts/shirt/socks under a pair of motorcycling overpants and riding jacket...so when I got to the trailhead, I just shucked my motorcycling gear, pulled on my cycling shoes and helmet and was good to go.
    Out of curiousity, I timed myself after my ride: from being fully clad in all my cycling gear (with the bike off the motorcycle) to loading the bike onto the motorcycle and getting my motorcycling gear back on was just under 8 minutes total---not bad at all! (And I wasn't rushing---just being efficient and not goofing around.) That's actually not any slower than it would take me if I were driving the car. (And besides, if I need to be faster than 8 minutes, I probably shouldn't have gone for a ride that day.)
    Like any rack system, I have a feeling the more I use this, the easier and faster mounting/dismounting bikes on the motorcycle will be. And having taken the time to provide for mounting my topcase, if I ever need all three hard cases (e.g. for a long trip), no problem---I just mount the topcase over the bike rack. (And I could also take a bicycle on a long trip too, with plenty of room in the sidecases, plus room to mount gear on top of the sidecases if needed.)
    So all in all, I think the $300 for this rack was worth it! It was pretty cool to go for a mountain bike ride on my motorcycle. :-) And the whole setup---as crazy as it looks---even passed the LEO test when I was passed on the interstate by a state trooper---who I'm sure was staring at the rig and thinking "WTF!?"
    Now my only remaining concern is whether or not I'll be able to get into the parking garage at work with a bike on the motorcycle. (I'll have to check clearance and see.)
    Scott
    29er wheels are dangerous. They may cause you to go faster which can result in serious bodily injury. óJim311
    Trail Cubist
    Hmm...65 views and not a peep---guess there aren't many people here who want to put their bikes on a motorcycle!
    Scott
    Thats awesome, I was thinking of a small trailer with a box for gear storage. That way you could even haul two and still ride two up.
    Ex-Clydesdale
    Reputation: Dwayne's Avatar
    Jun 2005
    There must be something about V-Stroms...
    '94 RSBikes Stampede (commuter), '05 Prophet, '09 Scattante XRL Team, '10 Slice 4
    Retired: 97 C-DaleSuper-V, 05 C-Dale R5000
    Trail Cubist
    Nice Dwayne! I bet handling is better with the bike farther forward. That's the only improvement I'd suggest with the 2x2 Cycles rack: an option for having the rack basically float over the passenger seat (farther forward)...I think that would help.
    Scott
    Oct 2010
    Fix the pics please! Good review, thanks!
    First off, thanks for posting your review. I recently bought a 2012 vstrom adventure and have been scouring the net to find an ideal solution to carrying my rip9 to the trails on it. I think the 2x2 is a good idea but I have a couple concerns with the design. The first, which you also touched on, is how far back the bike hangs off the motorcycle. I've seen a couple homemade rigs that either rest the fork farther forward, on the passenger seat area, or configure the rack so that the bike is off to one side of the rider and farther forward. I don't know if and how much having the bike off to the side would effect balance and handling but it may be better than having the bike hanging so far off the back. I could be, and most likely am, completely wrong but there is just something I don't like about how far back the bike hangs. The second concern I have about the 2x2 is how it uses the crank arm/pedal to support the bike. I wonder if this will have detrimental effects on the bottom bracket/bearings/crank arm to spline interface. It is very likely that there is no negative effect but I was thinking that this was a concern with Yakima ankle biter(?) Bike racks. They basically held the bike by wheel straps and an arm that "bit" or clamped onto a crank arm. Perhaps because the 2x2 more cradles the crank arm and pedal, it is an unfair comparison but I'm still curious. I certainly do not mean to say that the 2x2 rack is a poor design or not a good product. Hell, I'll probably end up buying one, once I figure out that buying the required materials, tools, learning to weld and then trusting my 'engineering' is too cost prohibitive and sketchy in general. Then again, I would have thought the same thing about building my own wheels, until I did some research, bought the materials and tools and whipped up a great set of flows on proII hubs this summer. Time will tell.
    I also wanted to add that I did one of my first races at Cooper's. It was after a typical WVU undergrad Friday night and I don't know if the hangover or riding the rocks on a full rigid gave me more of a headache but I had a great time, none the less. Go ,eers!
    Motion activated
    Reputation: Steve71's Avatar
    I've seen a couple of motorcycles arrive with MTB's at local trail heads a few times. Always makes me look!
    But I gotta ask, why not cut to the chase and get a dirt bike .
    Happiness is a warm 2 stroke.
    Reputation: awesomepaw's Avatar
    Oct 2010
    "There must be something about V-Stroms... "
    Indeed-e! First I heard about these 2x2 racks, then saw one from a distance (a dual sport) on the interstate and now, for certain, with these great pics intend to make this my next major MTB-etc investment. IMHO, Strom riders are trying to get the most practicality out of these great machines.
    Thanks for the great write up, Scott! Still happy with it? When I get mine, I'll add some pics.
    best,
    ap
    That's right. Shop smart. Shop S-Mart. You got that?
    Reputation: fourthree's Avatar
    Dec 2010
    Thanks for the review, been thinking of getting one of these for my klr, wind was my main concern, as my klr gets a bit busy around trucks and such.
    방랑외국인
    Reputation: motard5's Avatar
    thanks for the review. I am thinking about mounting one of these to my rear rack. I frequently (daily) strap and haul things on my existing rear rack (work, gym, camping gear etc). So is it easy to mount stuff over the rack and just remove the rear arm? Or is it best to simply unbolt the entire thing when not hauling a bicycle?
    Do you think this would work for a Giant Trance X 29er? Does it accomodate a 15mm thru axle?
    "Go big or go home." That was bad advice.
    Quote Originally Posted by msch1981 View Post
    I'm also wondering this, except in the 20mm variety. My only motorized transport is my KLR, so I've been contemplating all kinds of ways to build something like this to accommodate my FR rig.
    EDIT: I was also thinking about a surfboard rack that runs a board sideways along the motorcycle. There's some that are adjustable and would probably fit a bike well enough to be stable, but my concern would be weight capacity..
    Something like this: Carver Surfboard Moped Rack For Sale at Surfboards.com (146903)
    Reputation: gasnit's Avatar
    Dec 2009
    Yes it will accommodate a 15mm thru axle (or 20mm), I called and talked to the person who developed the rack. I have the rack on the way for my Z1000. I will be carrying a Specialized Camber Evo 29er with the 15mm thru axle.
    Jun 2014
    Has anyone using this tries mounting the rear wheel on the other side of the bike opposite to the front wheel?
    I feel that might help with the feeling of weight being far back...
    Make any difference?
    Jun 2014
    Ended up building my own
    Ended up building my own rack with just a piece of wood, 2 flat metal bars (:
    REVIEW: 2x2 Cycles Motorcycle Bike Rack-rack.jpg
    Total cost: $50 (half of that are the Lashing straps
    May 2015
    Quote Originally Posted by SWriverstone View Post
    Scott
    hi Scott found your post and review when searching for info about bike racks for motorcycles.
    First off, great pictures and info. I'm an avid cyclist (road and long distance touring) that recently purchased a 2013 650 V-Strom. My touring bike is a Surly Disc Trucker, pretty hefty.
    So how has the 2x2 setup worked in the long run? Any issues with traffic laws?
    My goal, if feasible....would be to have a setup that would allow me to go on long rides, even cross country to cycling events and campgrounds.
    Thanks,
    Richard
    Hooligan
    Reputation: dirtdawg21892's Avatar
    Quote Originally Posted by glesage View Post
    Thats awesome!
    I know its been 2 years, but i'm currently working on something for my SV650. any chance you could post up some detailed shots of the rack?
    Quote Originally Posted by Optimus View Post
    Hell of a jump, dawg. Even though they're baggy shorts, I'm surprised that you can fit your balls into them.
