Removing stickers w/o removing rack paint?- Mtbr.com
Results 1 to 9 of 9
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Im prepping my rack so i can sell it and need to remove stickers. Anything work better then scraping the edges and peeling um off? Any better way to prep so that the peeling will be easier? thanks
    Reputation: Neily03's Avatar
    Feb 2010
    Warm them up with a hair dryer then peel.
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    hair dryer or heat gun.
    you can use some wd40 as a release agent or mineral spirits to remove any remaining glue.
    jrm
    jrm is offline
    Awesome, Thanks guys
    if anyones interested in a 2 bike sportworks T2 hitch rack PM me.
    Reputation: Eamonn Wright's Avatar
    As was advised, warm with hair dryer, and peel. Any remaining glue can be safely removed with Goo Gone, which is around $3 at the hardware store.
    Reputation: 1996cc's Avatar
    Lighter fluid > goo gone or any other gimmick product
    2018 Transition Patrol
    ballbuster
    Reputation: pimpbot's Avatar
    You're dropping your sportsworks rack? Heh, I was with you when you bought that at Supergo.
    Good times.
    Oddly enough, I just scored a Thule T2 rack. Gonna sell the XPort Flatbed rack.
    jrm
    jrm is offline
    Ill buy your Xport rack
    Quote Originally Posted by pimpbot
    Good times.
    That was funny.
    thats what i was going to replace it with anyway. Also you got a 120mm x 5 stem around with a 25.4 clamp?
    Reputation: Kona_CT's Avatar
    Rubbing alcohol is what I use to remove the glue after.
    --NC
    2008 Kona Cowan // 2005 Kona Cowan // 2009 Giant Modem // 2009 department store IronHorse // 1970s Schwinn roadie
