Question about the 'channels' mounted to my SUV- Mtbr.com
Results 1 to 13 of 13
    Caca pasa
    Nov 2003
    Hope the pic turns out right side up.
    Anyhoo, how strong are these channels, for a lack of a better word? I was thinking of inserting a bolt, upside down, then through a metal crossbar so I can lash a kayak to the crossbars.
    I have a diagram I've drawn, if that explanation isn't clear enough. I'll try to get a good enough pic of it to post.
    Anti demagogue.
    Hogan Lake blog. A section of Hogan Lake trails here.
    Caca pasa
    Nov 2003
    Here's the diagram.
    Thanks.
    Anti demagogue.
    Reputation: rsb201's Avatar
    Looks like it would work ok to me. I did something similar in the bed of my Nissan Frontier utilitrac system along the bed sides. I actually used a spring nut (not sure of the proper name) that is used in uni-strut. Check in the electrical section of any Lowe's, Home Depot, etc... Good luck
    Caca pasa
    Nov 2003
    Quote Originally Posted by rsb201 View Post
    Thanks. Can you describe this "spring nut" in a little more detail, please?
    Anti demagogue.
    Quote Originally Posted by Finch Platte View Post
    https://ecx.images-amazon.com/images...lL._SY355_.jpg
    You could use these to secure your crossbars and a bolt that is the proper length and it would be a much cleaner look. The bolt would be flush to the crossbar instead of having it the other way as your illustration shows. Just an idea anyway.
    I'd assume that these channels are used by the aftermarket rack companies to add crossbars to the vehicle. While you may not get into those set up's, you might check out the carrying capacity with their set ups. They will show a maximum carrying load, max will be 165lbs, but if they show lower, it is worth noting as that lower number is almost assuredly due to to the rail connection.
    Kick Start My Heart
    Reputation: davez26's Avatar
    Dec 2004
    Here's the diagram.
    Thanks.
    I see you have a bolt head in the channel. I'd consider as large a washer as possible on the bolt head, to maximize surface area. Maybe even spend a little time with a fender washer (essentially a very large washer with a small hole) and cut it down to size like an oval to slide back and forth and increase contact on the underside of the channel.
    Sent from my XT1254 using Tapatalk
    Oct 2013
    Just use duct tape
    Sent from my Nexus 6 using Tapatalk
    Oct 2013
    Seriously, I would trust a square nut a bit more in that track.
    Caca pasa
    Nov 2003
    Quote Originally Posted by zombinate View Post
    I'm not really concerned about the weight, as I'd be transporting a kayak that weighs less than 60 lbs, I'd be more worried about the lift caused by the wind.
    But yeah, point taken.
    Anti demagogue.
    Caca pasa
    Nov 2003
    Quote Originally Posted by davez26 View Post
    Yes, that's a great idea. The bigger surface area the better. Thanks.
    Anti demagogue.
    Caca pasa
    Nov 2003
    So the spring is just to keep the nut from backing off?
    Anti demagogue.
    The spring in those is to hold the nut in place while you put the bolt in:
    Those probably won't fit into the tracks on your roof though, they're too thick. If you look at this picture of Yakima landing pads you can see the square nuts. You slide those into the track from the end, put your landing pad (or whatever) on top, and bolt it down. Question about the 'channels' mounted to my SUV-514x7ezqrzl._sl1000_.jpg
    You can buy the square nuts separately, you just need to verify the dimensions of your track: Replacement Anchor Plate "A" for Yakima LandingPad 1 (QTY 8) Yakima Accessories and Parts Y8810074
  1. Remote Mounted Rohloff Question
    By Sand Rat in forum Internal Gear Hubs
    Last Post: 05-23-2013, 05:37 AM
  2. Spare tire mounted rack to carry an sc blur lt2 question
    By RDI in forum Cars and Bike Racks
    Last Post: 04-24-2013, 11:34 AM
  3. toyota truck bed channels
    By canyonbrewer in forum Cars and Bike Racks
    Last Post: 01-25-2013, 08:23 AM
  4. Youtube UCI XCO Team Racing channels
    By chunky1x in forum General Discussion
    Last Post: 10-21-2012, 10:03 AM
  5. Youtube Channels?
    By alex5425alex in forum General Discussion
    Last Post: 05-05-2012, 10:59 PM
