New 29er won't fit in my Thule Insta-Gator truck rack?- Mtbr.com
Results 1 to 9 of 9
    I just bought a GF 293 29er this morning and it doesn't quite fit in my Sportworks/Thule Insta-Gator truck bed rack. I read the directions and it says to contact them if you have a 29er. Is there an extension of something? Any other fix for this?
    Bryan
    '05 Trek 5000
    '15 Camber Comp Carbon
    '15 El Mariachi SS
    Dec 2005
    I had the same issue
    I have a roof-mounted SportWorks rack and when I got my Rig, I couldn't (at first) figure out why it wouldn't fit. If you're having the same problem, you're not able to swing the retention arm up and over the tire...right?
    If so, the trick is to extend the ratchet all the way, put the bike in the rack and lean it slightly away from the arm mechanism. Then swing the arm straight up (90 degrees to the tray) and THEN pull the bike and tire under the retention arm. Then secure as you would any other tire.
    Hopefully this makes sense. Again, if you're having the same issue, once you figure out the lean-swing-straighten-secure it's pretty straight-forward and the bike DOES fit. And you're lucky...my rack is on top of my Montero. I'm tall, but that's still a long way up there.
    Reputation: zyzbot's Avatar
    I have a similar issue with my 29er and my Saris Cycle On rack. I had a similar solution as well...I extend the arm all of the way out and then push the bike/tire forward into the arm whilke pulling back on the arm. I also usually attach a bungee cord around the handlebar and then attach it to the bottom of the rack just for an extra bit of security.
    jl
    jl is offline
    climb
    Reputation: jl's Avatar
    Turn your wheel/fork backwards.
    We don't need more to be thankful for; we just need to be more thankful.
    Quote Originally Posted by jl
    I don't see that doing anything, the wheel is still 29" in diameter
    '05 Trek 5000
    '15 El Mariachi SS
    jl
    jl is offline
    climb
    oops... I thought your problem was fitting in the length of the bed
    Gotcha, that is an issue as well but I just kick the rear wheel to the corner of the bed. Thanks.
    '05 Trek 5000
    '15 El Mariachi SS
    the train keeps rollin
    Reputation: snowdrifter's Avatar
    Big Wheel Clown Bikes : )
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by TuksonRig
    This is the way I put my 29ers on my Bob Ratchet/Sidearm rack
    mtbtires.com
