Info re: 1Up Super Duty single and add-ons- Mtbr.com
Results 1 to 7 of 7
    Reputation: windsurfdog's Avatar
    Apr 2018
    Thinking of purchasing a tray based rack to replace an aging rack that requires a bike rack adapter bar setup. My current vehicle is a 2014 Ram. After considering racks by Saris, Thule, Yakima, et al, I've decided to purchase a 1up Super Duty Single with the idea that I will have enough clearance to leave the rack in normal usage position and be able to let my tailgate down covering the rack. If anyone is using the rack with a same or later model Ram and can provide insight, I'd appreciate the info.
    I also plan to get an add-on which will normally not be used but available. Looking at the Add-on and the Super Add-on, I was wondering if either would fit the Super Duty so I contacted 1Up via email:
    "I'm seriously considering a 2" Super Duty Single rack for 90% of my biking adventures. I'm also considering either an Add-on or a Super Duty Add-on for those times when hauling 2 bikes is necessary. Are both add-ons available for this scenario? Or is there a dimensional difference between the 2 that would require the Super Duty? If either can be used, are there other considerations that would make the Super Duty worthwhile?"
    The 1Up response was very quick (a big positive!):
    Thanks for reaching out. The Add-Ons will fit exactly the same. The super duty model will be rated to hold a bike exceeding 50lbs. Unless you planned to carry an ebike, there wouldn’t be a need for it unless you wanted additional strength."
    Add-on info:
    • $20 less than Super Duty
    • .5 lb. less than Super Duty (18 lbs. v. 18.5 lbs.)
    • Rated to carry 50 lbs. Super Duty rated 50-75 lbs.
    So I'm thinking of getting the Super Duty add-on for now and, should I decide to add-on again, maybe scale down.
    Hope this info will be valuable to others going through the same decision making process.
    Thanks in advance for playing along.
    2018 Fuel Ex 5 27.5+
    Bontrager Dropline 125
    Ergon GP1 BioKork grips
    Pedaling Innovations Catalysts
    I've got the SD Single and a regular Add-On for my Ram.
    2016 Ram 2500 with 2.5" hitch and the 1up adapter piece
    Normal single rack position, the tailgate just touches the rack.
    Tilted out, tailgate clears rack
    Bike on tilted out, tailgate clears when pedal is up on inside.
    I haven't used the add-on on the single so far, only on a 1-1/4" hitch adapter (no folding) for the little car.
    Apr 2018
    Quote Originally Posted by RPS1030 View Post
    Excellent info, RPS. When the single is tilted out sans bike + the tailgate down, does the tailgate completely cover the hitch? Thanks for your input.
    Quote Originally Posted by windsurfdog View Post
    Going from memory last week, it gets close to covering it, but not completely.
    They have awesome measurement charts...
    https://www.1up-usa.com/wp-content/u..._FITMENT-1.pdf
    Reputation: OldHouseMan's Avatar
    It is slightly less expensive to go with a Heavyduty double than a Superduty single plus an add-on, if this matters.
    Also, if you do get a single rack now, then decide to get an add-on down the road, 1up will not supply matching keys to additional locks after the initial purchase.
    I only ride bikes to fill the time when I'm not skiing.
    Apr 2018
    Yep, saw that...excellent info. As you said, the measurements are very close. Thanks for your insights.
    Apr 2018
    Quote Originally Posted by OldHouseMan View Post
    Yes, I have considered the 1.25" model but feel a little more comfortable with the 2" setup...especially if I choose to add an e-bike or 2 in the future.
    Good catch on the matching keys. I'll have to consider that as well. Thank you for the insight!
  1. 1up Double or Single + Add on
    By Farslasher in forum Cars and Bike Racks
    Last Post: 03-07-2018, 08:58 PM
  2. Bought a 1up super duty double rack
    By mudguy in forum Cars and Bike Racks
    Last Post: 01-14-2016, 09:51 AM
  3. Morrison Monster add-ons?
    By rmac in forum Colorado - Front Range
    Last Post: 04-23-2014, 08:00 AM
  4. cargo bike diy add-ons
    By PretendGentleman in forum Cargo Bikes
    Last Post: 11-06-2012, 10:28 PM
  5. Braze-ons or no Braze-ons??????............
    By MKD in forum Singlespeed
    Last Post: 04-12-2004, 07:42 AM
Members who have read this thread: 88
