How much trailer hitch flex is acceptable- Mtbr.com
    I'm always fixated on my rear-view mirror when hauling bikes watching the hitch rack bounce on bumps. The rack is pretty sturdy and well attached to the hitch so I think it is the hitch flexing.
    Do hitches ever break? Mine is a class III, rated with 350 lbs tongue weight. My rack fully loaded weighs about 225 lbs, but the fulcrum is moved away from the tongue. Does anyone know much about hitches who could comment? I have been told by some not to worry, but am looking for other opinions.
    Come see me after class
    Dec 2005
    if the receiver (what you're calling the hitch) is properly secured to the vehicle (i.e. no missing or loose mounting bolts) then it is not going to sway or flex or move. period.
    the bouncing you're seeing is the rack, not the receiver. what kind of rack is it, and how is it secured into the receiver?
    Thanks for the response.
    It is a North Shore Rack. It is held in the receiver by a square shaped nut which is inside the square tube that goes into the receiver.
    There are no missing bolts. It was recently installed using a torque wrench.
    The rack does have a rather long arm, so perhaps that is all that I am seeing which I am much more comfortable with.
    Reputation: OscarW's Avatar
    Feb 2010
    A receiver should have zero movement when installed properly period. 225# on a long arm will give you movement and IMHO that is what probably makes the whole assembly move a bit.
    Current ride(s) 2011 Santa Cruz Blur LT and a Norco Threshold SL with Di2
  1. Hitch bike rack - Too much play in trailer hitch
    By matsis in forum Cars and Bike Racks
    Last Post: 05-27-2009, 07:05 AM
  2. Volvo V70 trailer hitch
    By nbwallace in forum Cars and Bike Racks
    Last Post: 03-11-2009, 09:39 PM
  3. Trailer Hitch installation?
    By batangueno in forum California - Norcal
    Last Post: 02-12-2009, 07:26 PM
  4. OT: Trailer hitch recommendations?
    By dir-T in forum General Discussion
    Last Post: 08-25-2006, 08:30 AM
  5. How much flex is acceptable
    By Trajan in forum Shocks and Suspension
    Last Post: 05-26-2004, 05:02 PM
