How to lock hitch rack to hitch?- Mtbr.com
Results 1 to 17 of 17
    Is there a locking bolt or something like that to lock my hitch rack to the car's hitch?
    Ok. Just found out that the local autopart stores carry a generic hitch lock. Any particular brand/type I should get or avoid?
    Was that a Bobcat?
    Reputation: amor587's Avatar
    Dec 2004
    Can't go wrong with Master's products.
    Are all the pin diameters the same?
    Was that a Bobcat?
    Dec 2004
    There may be a couple diameters 5/8" and 1/2" diameter. My Master lock has a sleeve that can be removed or taken off the center pin to accommodate both these sizes. Hope this helps.
    Didnt see this in my lbs. Did you order it online?
    Careful it may not fit. I bought a .5" masterlock and it wouldn't get past the threads in my Thule Parkway. It also wouldn't fit a Yakima 2 bike b/c the hole is too small. I wound up drilling out the threads but it's still tough to align.
    Mountain: Scott Spark 20
    Road: GT GTR Rival
    Was that a Bobcat?
    Dec 2004
    I bought it at the local auto parts store.... but mishap has a good point, make sure that these products will fit your bike rack. You may need to drill out the threads as mishap indicated. You can always ask your lbs what lock they recommend.
    I think I've seen them in the auto supplies aisles of Target, Walmart etc.
    If all else fails, go to Sears and get a spare hex key as well.
    Either you rode today, or you didn't.
    Oct 2007
    Quote Originally Posted by mishap
    I've got the same problem with my Yakima hitch rack. The threads won't allow a lock to fit in, but the problem then is that without the bolt threading into the threads, it seems like there would be a lot of side to side movement of the rack. (because the rack doesn't fit snug in the reciver hitch. I guess a shim of some sort could be used, but that might fall out.
    Do you get alot of side to side movement?
    Oct 2007
    Exactly....
    Quote Originally Posted by Vernon Dozier
    Short answer: Yes
    Long answer: I have a Thule hitch rack. I drilled a seperate hole for a hitch lock closer to the vertical post so I could slide the rack into the hitch further to help stability.
    I drilled the hole as tight as it could get (need to grease the lock bolt to get it through) and I still get significant side to side movement. The screw basically locks it in place and makes a big difference in movement.
    Ive thought about shims too... But yet to try. Have you tried yet?
    Just saw that thule makes a lock that has the screw integrated (on their website). Little pricey though
    Oct 2007
    Quote Originally Posted by kramerica
    Short answer: Yes
    I just got my rack and have bolted it in every time except once, when I didn't thread the bolt tight, there was too much side to side play. A couple of shims made out of wood would work, but might be a biatch to get out at the end of the day, especially if they get wet.
    Master of None
    Reputation: presslab's Avatar
    For side-to-side play try using a Draw-tite J pin. It just works. You will need to drill another hole in the receiver though.
    Daddy of 3 now!
    Reputation: daddy2's Avatar
    Drill ? why?
    I have a Yakima KingPin5 Rack and bought the Yakima Lock that attaches to the end of the pin. Just screw the threaded pin and put lock on the other side. Once tightened there is no sway in the rack.
    http://www.rei.com/online/store/Prod...:referralID=NA
    Oct 2007
    Quote Originally Posted by daddy2
    That was a great idea.........
    I went to the LBS and picked one up for $20.
    Nov 2006
    Vernon Dozier
    Hey Vernon, I heard Herb Sewel was sent back to Atascadero.
    Oct 2007
    Quote Originally Posted by rewarder
    Mmmmmhhhmmmahahahah!!!! He went to go see Walter Bellhaven and just decided to stay.
