How do you fasten the nylon straps to the buckle of trunk rack- Mtbr.com
Results 1 to 6 of 6
    I have a Graber Mountaineer Rak(that is how they spell it, not Rack) and my brother undid all the straps from the buckles. Now I cannot figure out how to secure them properly. I have been using it regardless the wrong way, as result the nylon straps loose tension and often even unhook from the trunk as I drive.
    Can someone tell me how you are supposed to loop the nylon straps into the buckle?
    Here is a pic of the buckle:
    Check out how they do your wife bra.
    they have similar straps.
    I can see one in the background that is done up properly, it is a simple ladderlock buckle. check out this for a side on diagram http://www.fastex.com.au/ladderlocs.htm
    guwoxygbly
    Guest
    You Can Love The Post
    MAC, Contrast or Deep Truth may be worth a look ,mac-makeup-brushes webs com/#27193]wholesale mac makeup
    Reputation: dynamicz's Avatar
    http://www.saris.com/pdfManuals/Sent...20Sentinel.pdf
    Just like my Saris Sentinal. Check out instruction #4 & 5
    With the extra slack line I just run it around the bike frame or rack frame and knot it
    **fooled by a spammer reply!!!!***
    Dec 2012
    valuable lesson
    I learned a valuable lesson to always double back on all clasps. It's well known that truck racks should be checked on a regular basis while traveling, but i've noticed it helps alot to reduce them from loosening if I double back them. When I say double back I mean running the strap in the clasp like you normally would and then back around the same clasp.
