Hitch ground clearance issues- Mtbr.com
Results 1 to 9 of 9
    Reputation: dump's Avatar
    Greetings fine folks of MTBR. After many years of putting bikes into the car and trunk, a little man arrived and baby stuff goes where bikes previously went, so we got a hitch and the amazing 1up rack.
    Went on etrailer, picked the hitch that fit the vehicle and installed it myself. Bolted up w/o much issue.
    The car is a 2005 Subaru Legacy. It sits pretty low as is, but I expected the hitch to tuck up under the bumper a bit more like other hitches I've seen. I get strikes when pulling out of sloped driveways and sometimes even on speed bumps when loaded!
    Current clearance is about 6.5 inches unloaded.
    I'm running regular tires and suspension (i believe)
    This is the hitch:
    Trailer Hitch for 2005 Subaru Legacy - Hidden Hitch 87446
    Any suggestions on how to remedy the situation?
    Images:
    Thanks.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Take them at an angle slowly. With the rack drive it like its a sports car with 4" of clearance. Don't drive the car into a place you are not sure you can get out of. I had a receiver on a wrx and v8 Camaro with nary a problem and no scrapes.
    Hi Jayem,
    thanks for the feedback. In short, nothing to do but drive carefully. Will give it a go!
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Would a hitch riser/drop work?
    Quote Originally Posted by jrm View Post
    Don't think so. It's not the rack that's low, it's the actual hitch. A riser would just make the rack attachment point higher while the position of the original mount is unchanged.
    mtbr member extraordinair
    Reputation: Stupendous Man's Avatar
    Is that a hidden hitch? That's odd, usually they are tucked up more closely under the bumper. Perhaps its just the way the car and hitch are designed. Unfortunately without throwing gobs of money into a custom solution, I don't think there is much you can do other than drive cautiously with the lowered ground clearance.
    Grit, spit, and a whole lot of duct tape!
    Reputation: watts888's Avatar
    Oct 2012
    Looks like it does on the demo car from the etrailers website. Unless you try to find a different manufacturer's hitch that sits further forward, this is what you've stuck with. Drive slow and avoid the steep driveways and big speed bumps.
    Hidden Hitch, Curt, Reese, Draw-Tite are all made by same manufacturer and are probably identical.
    You already have this hitch, its far easier to just drive gently when needed as opposed to getting a new hitch.
    Cool, good to know. Thanks for the info.
  1. Timing Chain Ground Clearance
    By Lelandjt in forum Tandem Mountain Bikes
    Last Post: 12-26-2014, 02:58 PM
  2. Frame with best ground clearance
    By nodak in forum General Discussion
    Last Post: 06-03-2014, 08:58 AM
  3. Remove outer chainring to improve ground clearance?
    By teachndad in forum All Mountain
    Last Post: 09-03-2012, 11:07 PM
  4. Hardtail vs Full Suspension - ground clearance question
    By lifanus in forum Bike and Frame discussion
    Last Post: 03-09-2012, 11:52 PM
  5. 29-3 TLR 2.25 clearance issues?
    By A1an in forum Gary Fisher
    Last Post: 01-03-2011, 08:24 AM
