hidden hitch for bike rack?- Mtbr.com
Results 1 to 11 of 11
    Apr 2005
    I have questions about hidden hitch for bike rack.
    what is average cost for getting hidden hitch for bike rack?
    Is the hitch strong enough to support the bike rack?
    XCfosho15
    Guest
    recently got a hidden hitch for our Honda Odyssey. it seems to be fine with 120lbs on it. i think it was around $130 at etrailer.com. just go to their website and you can find a hitch that will work with your specific vehicle.
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    the are generally rated for at least 200 lbs of tongue weight, so it sould haul a rack and 4 bikes with no problem.
    "Knowledge is good." ~ Emil Faber
    got mine from www.etrailers.com for $130 shipped. should tell you online how much weight they can carry but mine has worked fine for probably 130ish lbs. I trust my hitch. do it.
    Slowest Rider
    Reputation: BigLarry's Avatar
    Quote Originally Posted by rckhopper87
    Ditto. Also got my Hidden Hitch from eTrailers for $130.
    The car often limits the hitch tongue weight, which is usually about 10-15% of the tow weight.
    It's not slow, it's doing more MTB time.
    I just got a hitch for the element. It is a hidden/Valley Uhaul Hitch with a 2" receiver for 105 shipped. It was a store on ebay that was posted in the element forum. Save the cash and do the install yourself as if the hitch is designed for your vehicle it should make use of holes already there. Took me 30-45minutes to install and that was running to get tools that I needed.
    The weight the hitch can take is dependent on class. A Class 1 with a 1.25" receiver will have a tongue weight lower then a Class III with a 2" Receiver. Get a hitch with a 2" receiver as the accessories are way more common for that size.
    Reputation: tk1971's Avatar
    Just remember that with passenger cars that have limited ground clearance (sports suspension, or just plain lowered), you will have limits of what rack you can use. Even with a rack that hangs the bike by the frame, my brother's Accord could not use his Softride rack (bikes would hang too low). Some wheel tray racks are higher than others as well. Shop accordingly.
    tk
    Quote Originally Posted by tk1971
    tk
    Good point - I think also if it is a car he may only be able to get a class 1 hitch with a 1.25" receiver. The 2" receiver is more common and it is easier to find accessories for. If this is the case then when you step up to an SUV you will be stuck with the 1.25" rack and have to either get the size hitch on the SUV or use an adapter to run the 1.25" rack in the 2" receiver. Either way you will be limited by the amount of bikes you can carry with a 1.25" rack. For example the Thule T2 you can only get the 2 bike rack with the 1.25". The 2" lets you carry 4. I think this is the case for most racks.
    Slowest Rider
    Quote Originally Posted by kaikara
    With a passenger car, a major limitation on the rack will be the permissible tongue weight. Look it up in your driver's manual. Generally it's about 10% of the tow weight, or maybe 150-300 lbs, depending. At the low end of weight capability, you're not going to be able to hold four bikes and a rack. Get a roof rack if you need more than two bikes.
    You can always put on a 2" rack if it's sold for your car. And it makes sense to have the additional rack capability of the 2" receiver. But you still need to obey the weight limitation for car dynamics.
    LDH
    LDH is offline
    Reputation: LDH's Avatar
    Got a 1 1/4" HH from etrailer and use a 1 1/4-2" adapter to move the rack back 6" as the hitch was tucked under too far to fit the first bike. I carry 4 bikes all the time and check everything carefully each time and have had no problems (sagging ,loosening, damage etc).
    ~I Ride In Circles ~
    Reputation: ZoSoSwiM's Avatar
    Dec 2005
    etrailer... Love that site. got myself a Curt hitch for my Impreza for just over $100
    ~ it's all good ~
