Fork mounts on a truck bed cover?- Mtbr.com
Results 1 to 6 of 6
    I got a new truck and it came with an Undercover Tonneau cover. Can I mount fork mounts directly to the cover and let the bikes ride on top?
    gran jefe
    Yes, but they might crack the cover.
    Reputation: arphaxhad's Avatar
    Sure,
    Just make sure to use a really large backing plate under the cover to distribute the loads introduced by the weight of the bike and the lateral forces from when you drive/corner etc. If it was me, I would also mount a plate under where the rear wheels contact and use some sort of anchor to strap the rear wheels to. Also, the further forward you mount it the sturdier it will be.
    gran jefe
    Backing plate is an excellent idea. If the cover has any built-in stiffening structures, you could try to utilize those.
    I mounted Yakima rack and high rollers on my ARE cover. Works great no cracks
    I took the advice offered here and used a heavy guage (~1.5 mmm thick) to mount under the QR mounts before bolting them to the bed cover. There is some wiggle but not a lot. I then drag the rear wheel of the bikes towards the center of the truck which increased the resistance to wiggle. I uses velcro with adhessive backing to create a lightrear wheel holder. However, drawing the rear wheel towards the center of the bedline adds a fair amount of pressure due to the headange so not much holding is needed to secure the bikes. I made it from DC to Augusta, GA with no problems.
    Now I want a good tent that incorporates the cover. I've seen some tents that are set up in the back of a truck but they require cover removal.
  1. Replies: 15
    Last Post: 03-02-2012, 08:52 PM
  2. 2012 Reba RLT fork will not fit 2011 Epic
    By dmboarder in forum Specialized
    Last Post: 01-15-2012, 09:16 PM
