Fork Damage. truck bed mount- Mtbr.com
Results 1 to 5 of 5
    Reputation: Hudnut's Avatar
    Apr 2005
    I just put together a fork mount bar for my truck bed. This is a common configuration but I'm worried about damage to the forks of my bikes. one is a through axle and the other is a QR. I'm thinking that without having the rear wheel strapped down that the bike will bounce up and down a bit. If this happens and the fork mount can't pivot then the interface between the mount and the fork will rub and wear down and damage the fork lowers. Am I over thinking this or has anyone had a problem before. Here's my setupFork Damage. truck bed mount-80-20160109_124120_23ed27ad9cedb05d9a7986a0fadfaca3c2bbf05c.jpg
    Ride in heat
    May 2012
    Can't imagine how it can affect the forks, since a fork is under much more stress during rides. But I still would want to fixate the rear wheel somehow at least for a side-to-side movement. Could you please give a close up of the fork mounts themselves? I might copy it for my truck either ))))
    Apr 2005
    the damage will be to the fork from rubbing against the fixed mount not to an impact. When a wheel is mounted to the fork the interface between the hub and fork is stationary, the bike rotates around the hubs bearings. In the bed mount, if the bike is rotated around the mount there is no bearing for it to rotate around, therefor something has to give and the fork will grind against the mount.
    Reputation: dietz31684's Avatar
    You're all good man. I have a buddy with the exact setup made by Thule. Just clamps the fork dropouts and the rear wheel isn't fixed. He has used this setup for years with no problems.
    Sent from my VS980 4G using Tapatalk
    Reputation: flyfisher117's Avatar
    I run mounts like that on the lid of my pickups toolbox. So far the bike has has ridden my pickup for roughly 1800 miles and I have seen no damage. Even going down washboarded gravel roads the fork was fine. And Im only running a basic SR suntour fork on $11 mounts from Amazon.
  1. My wooden fork mount truck bed rack
    By sigurd02 in forum Cars and Bike Racks
    Last Post: 05-01-2012, 08:31 AM
  2. Built a new truck bed mount
    By cobi in forum Cars and Bike Racks
    Last Post: 04-15-2012, 10:29 AM
  3. Fork mount racks and damage?
    By js_paddle07 in forum Cars and Bike Racks
    Last Post: 11-05-2011, 09:40 PM
  4. 20mm Truck Bed Fork Mount Recomendation
    By Lil' Red in forum Cars and Bike Racks
    Last Post: 08-16-2011, 09:19 AM
  5. truck bike mount
    By awamser in forum 29er Bikes
    Last Post: 07-02-2011, 08:02 AM
