Cheapest fork mount for inside the jeep- Mtbr.com
    Hey, I am looking for a cheap way to mount bikes inside my Grand Cherokee. I am thinking that I will get some fork mounts and put them on a simple 2x4. Where is the cheapest place to buy these fork mounts. Thanks Guys
    skobiken
    Pricepoint
    http://www.pricepoint.com/detail/145...Bike-Mount.htm
    Performance
    http://www.performancebike.com/bikes..._400007_400019
    Same price at both. $9.99
    I'd probably give the xport from performance a try. I have two of the sette version, and the skewer is a bit shorter than I'd like. The sette works great with rockshox forks, but for the thicker dropouts on fox forks the skewer is just barely long enough. Not sure if the skewer on the xport is any longer, but it's worth a shot.
    Jan 2005
    just use a bungee around the seat post and over to your rear seat belt mount on the side of your cab.
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    check out the Thule 821 LowRider....it's got a good 9mm skewer...perfect for attaching to a 2x4.
