cargo box and bike rack- Mtbr.com
Results 1 to 17 of 17
    Dec 2012
    I'm looking for a hitch mounted cargo box similar to this
    ROLA 59108 - Fixed shank with 1/2 in. pin hole 1.25" Receiver - Hitch Cargo Carriers
    but with another hitch attachment for a hitch rack
    anyone know if one exists? the closest thing I can find is this
    B-Dawg BD60203TO Steel Cargo Carrier with towing option 60" x 20" x 3"
    Reputation: watts888's Avatar
    Oct 2012
    That really starts moving the weight away from the hitch. The hitch adapters are designed to only handle so much torque (not to be confused with load), and when they get extended out like this, it can easily exceed the torque. I'd look for a hitch box where you can mount a bike on top of the box instead. I've actually added a fork adapter to a metal cage hitch box. Put the bike in the box, pack stuff around it, and go.
    "a hundred travel books isn't worth one real trip"
    Dec 2012
    the only problem is that the suv i want to look into purchasing has crap cargo space, so i'll have to add some room somehow...would like to avoid anything on the roof for gas mileage, and would need to carry at least two bikes
    Oct 2012
    Two bikes plus some cargo, easy.
    Two of these fork mounts :
    http://www.amazon.com/Delta-Cycle-Hi.../dp/B000ACAM7E
    attached to a hitch rack with U-bolts.
    Aluminum Hitch Cargo Carrier - 500 lb. Capacity
    Bike carrier when you want it, added cargo space when you want it, carries both bikes and cargo when you want it. This is a 2" hitch, but I know amazon carries 1.25" hitch cargo racks too.
    If you really want to push it, it looks like you could also drill out a hole for a hitch rack on the back of that alloy cargo rack. I'd try to keep it as far forward as possible though.
    Dec 2012
    i'd like to have as much covered cargo space as possible...in my first post, second link, they have a cargo rack and the towing hitch available...wouldn't that exceed torque specs on the hitch?
    Does that mean the SUV you are looking at is too small? Consider the amount of time you will be transporting bikes and the amount of time a solution like a roof mounted cargo box would be required.
    If you are transporting bikes a lot more than hauling cargo, a nice hitch mount rack would be ideal. If you are only using the cargo box a few times a year, finding a easy roof rack system and box would be ideal. Maybe find a SUV w/ a good factory roof rack and simply add a cargo box. Honestly, when you think about the % a cargo box degrades the fuel econ, it ain't that big of a deal (as long as it is not on 24-7/365).
    Jan 2009
    Quote Originally Posted by watts888 View Post
    Agreed.
    Would a trailer be a better idea for you?
    Not sure if there's a European style rear hatch rack available for the SUV you have in mind, but here's a setup I had on a VW Eurovan. Paulchen bike rack with a Stowaway2 cargo box.
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
    Reputation: StuntmanMike's Avatar
    If the SUV you're looking at has "crap interior space", then what's the point of looking at it? The "U" is supposed to stand for UTILITY.
    Or get a wagon. My Volvo 70 series has more interior room than most so called "suv's".
    '15 Charge Cooker Maxi 2
    '13 Salsa Horsethief 2
    '12 Trek 6000
    '11 Ridley X-Ride
    '11 Santa Cruz Driver 8
    Dec 2012
    right now started looking at a grand cherokee ecodiesel...all other SUV diesels have scandals attached to them
    need the diesel to be able to pull about 4500 lbs and for better mileage on long distance trips
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Pulling 4500lbs and good highway gas mileage hardly require a diesel engine. I'll bet there are MANY gas suv's that pull that much and get at least equal mileage. I think you are severely limiting your options by focusing on a diesel.
    I'm a mountain bike guide in southwest Utah
    Dec 2012
    what other options are there? a 2014 used grand cherokee diesel getting 22 city/30 hwy towing up to 6500 lbs can be had for 28k on the low side...420 ft lb of torque at 2k rpm
    i haven't really looked into any gas engines but am open to all suggestions
    Your Best Friend
    I'm not going to do all of the research for you but a 2014 Ford Explorer gets 20/28 mpg which is close enough that the price difference between fuels more than offsets the diesel. It also tows your limit. I'll bet it has more room inside too.
    Dec 2012
    the explorer has even crappier cargo area...not finding much
    Your Best Friend
    Fair enough. I own a diesel Excursion so I get the appeal. If I had a smaller SUV, for myself, I'd definitely go gas for less expense.
    Feb 2016
    Then why not pick up a Ram 1500 with the EcoDiesel..
    Jan 2009
    GMC has a Canyon Duramax diesel this year if you can roll with a pickup and cap?
    Maximum trailering rating of 7,700 pounds (3,492 kg) for 2WD models and 7,600 pounds (3,447 kg) for 4WD
    Gross Vehicle Weight Ratings of 6,000 pounds (2,721 kg) for 2WD and 6,200 pounds (2,812 kg) for 4WD
    Canyon Small Truck Duramax Diesel Details - GMC Life
    Dec 2012
    I may look into trucks, thanks for the suggestions, but man that 1500 is a little too big...in the end, I may just go with a roof cargo system plus hitch rack
  1. Gravity G29 rear cargo rack
    By vassock in forum Commuting
    Last Post: 06-26-2015, 12:38 PM
  2. Hitch-mount Rack for Cargo Bike?
    By mtb143 in forum Cargo Bikes
    Last Post: 03-13-2015, 06:53 PM
  3. Homemade Hitch Rack for Bikes & Cargo
    By lunchwagon in forum Cars and Bike Racks
    Last Post: 07-01-2013, 12:14 PM
  4. cargo rack
    By SRock24 in forum Cars and Bike Racks
    Last Post: 03-28-2012, 11:12 AM
  5. Bike rack cargo trailer thingie?
    By vwtrey in forum Cars and Bike Racks
    Last Post: 08-28-2011, 07:52 PM
