Bike sliding on rack- Mtbr.com
Results 1 to 12 of 12
    Apr 2013
    I have an elderly Thule hitch mount rack for two bikes. When carrying a bike on the outside set of rubber pads, they tend to slide in, toward the car and other bike. Am I better off to glue the pads in place, screw the pads in place, or something else?
    Reputation: watts888's Avatar
    Oct 2012
    This is very similar to the cheap harbor freight bike racks problem. OK rack, but the craddles slide. Easy solution for it was a pool noodle or water pipe insulation from a hardware store cut and slipped over the rack. Tape the foam down. Life is good.
    "a hundred travel books isn't worth one real trip"
    Apr 2013
    Brilliant. Thanks. The hardware store opens in 7 minutes. I can be there in 12.
    Aug 2014
    I had that issue on an old rack in college. Used hose clamps to hold the mounts in place
    '15 Niner Jet 9 Carbon
    '19 Karate Monkey
    Motobecane Boris
    Raleigh Willard 3, Furley & Militis 3 (SS)
    Nashbar Carbon Road
    Reputation: Wombat's Avatar
    Quote Originally Posted by blkangel View Post
    I also do this on my Thule rack.
    I also found that the outer most bike would push the rubber bumper at the end of the bar off and the bike would then slide off onto the road. This only happened once, and only to 1 wheel so I didn't lose the bike. I put a self tapping screw through the bumper and into the bar and it hasn't happened since.
    Tim
    Reputation: CHIEF500's Avatar
    Thanks for the idea, I started putting clamps in mine to stop the sliding. Works like a charm.
    Oct 2012
    Quote Originally Posted by CHIEF500 View Post
    ..I started putting clams in mine to stop the sliding.
    I bet that smells weird.
    Quote Originally Posted by watts888 View Post
    Actually the clams didn't help much and made the bikes slide even more. I reread the post and realized I needed clamps. Now it works like a charm.
    Quote Originally Posted by Wombat View Post
    Tim
    Side of the bumper into the tube or the end?
    Apr 2013
    Any pics of the mentioned solutions? I have the issue with a new Thule trunk rack. The rubber cradles slide along the support bars. I am trying hair spray to make them tacky but doubt that's going to work.
    Oct 2012
    Google image. I wouldn't be quite this cheap looking though. in a home depot/ace hardware store, they have thinner grey pipe insulation back by the water heaters. costs like $2 for more than you'd ever need. Put some on, wrap it with black gorilla tape. Hose claps will also work instead of the foam, but you'll want tape or something underneath them. Hose clamps would give a stronger clamp force if the foam doesn't work out.
    Everbilt 1/2 - 1-1/4 in. Hose Repair Clamp-6712595 - The Home Depot
    Sorry, didn't see this earlier. The screw went through the bumper from underneath and into the tube. Tim
  1. My bike is sliding too much
    By G a r y in forum 29er Components
    Last Post: 04-17-2015, 04:20 AM
  2. North Shore 4 bike rack. Can you lock the bikes to the rack?
    By Rated R in forum Cars and Bike Racks
    Last Post: 01-11-2015, 07:50 PM
  3. 2nd Chance Bike Rack - Now Jaguar F-Type Bike Rack
    By Way2ManyBikes in forum Riding Passion
    Last Post: 07-21-2014, 12:55 PM
  4. Help me identify these bike rack parts! For a custom motorcycle rack!
    By doyouwantaspoon in forum Cars and Bike Racks
    Last Post: 06-26-2014, 11:34 PM
  5. Chainstay length, sliding dropouts and bike handling...?
    By The_Mickstar in forum Singlespeed
    Last Post: 01-12-2011, 01:25 PM
