Bike Rack For GMC Truck- Mtbr.com
Results 1 to 5 of 5
    New question here. Bike Rack For GMC Truck
    I have a GMC Denali Crew Cap with a 2 inch hitch, weight capacity is no issue. I need to carry two bikes minimum. However, I don't want to deal with anything that has rubber straps to hold the bike's frame because I have found that most carriers have not fit my bikes frame well because of the rear shock and water bottle holder.
    Feb 2010
    I Get bed mounts. You can cut a 2x10 the with of the bed. Set it in and then mount bike mounts to it. Otherwise I know Yakima has a hitch rack which holds the whole bike upright.
    Hey, I just ordered a set of these rain gutter brackets from a company called Summit Racks. Basically, itís a rain gutter bracket system that mounts to the bed rails of your pick up truck and allows you to install a standard rain gutter style rack system, so you can use whatever Thule or Yakima rack base and accessory you want. Iím plan to set mine up with a Yakima high-roller upright bike rack and possible add a cargo box for more gear storage.
    Looks like you can install a bed cover over the brackets as well!
    They also offer brackets for Toyota and Nissan trucks with cargo-management rails.
    Hereís a link to the site.
    http://www.summitracks.com/
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    the summit racks brackets are nice, and a good idea. i like how they work with a tonneau cover too.
    i think the OP was looking at a hitch mount bike rack for 2 bikes that was a platform style rack, like the Kuat NV, or the Kuat Sherpa, Thule T2 or Yakima Holdup?
    Quote Originally Posted by cracksandracks.com
    Or a Saris CycleOn. Nothing touches the frame or fork.
