Bike Rack for 06 Toyota Tundra- Mtbr.com
Results 1 to 18 of 18
    Kingflys
    I am looking for a very inexpensive form of transporting 2 bikes in the bed of my 06 Toyota Tundra. I've seen some rather elaborate looking racks but seem to be over $100.
    What's the best method or equipment out there where I don't have to drill into the bed to install? Any suggestions? Any links that I can reference?
    Thanks for the help!
    KINGFLYS
    Top is offline
    Why don't you just tie the bike(s) down like a motorcycle in the bed and then run a cable through the frame(s), hook the ends to your truck? That way it will only cost you the amount for the cable.
    Reputation: gixxerjasen's Avatar
    There's a few on this page that are well under $100. I'll be picking one up for my ranger here very soon.
    http://www.nashbar.com/results.cfm?c...it=y&pagename=
    Delta fork mount. Attach to 2x4. And you can lock it.
    I have a Tacoma and i did this.
    http://www.toyotanation.com/forum/t120255.html
    not sure if you have a bed rail.
    this is a cool site for your truck. Check it out.
    http://www.toyotanation.com/forum/f77
    Trek 3700 22.5 Black 2007
    Spend $20 at Home Depot and get (4) 6-foot tie downs and a long cable and Master lock. Easy, cheap, safe. You can buy half inch thick cable up to 20-feet long that would be very hard for someone to cut through. In the end, remember though if someone really wants your bike there is a way to steal anything.
    Sep 2004
    I have a Tacoma and use the Rec-Rac system. (sorry no pics here at work).
    Reputation: mountainbiker9109's Avatar
    I have a 06 Tundra as well. I am looking for a way to stand the bikes up lin a rack like the ones gixxerjasen gave from nashbar.com, but I would like to keep the wheels still on the bike because I have bolt on axels not quick release.
    http://www.orsracksdirect.com/sportw...racks-rhr.html
    Get two of those, they are an awesome bargain at that price.
    I really wish I could use one, but my bed is too short for the wheelbase on my bike.
    CharacterZero:
    Will that holder fit a 2.5 inch tire?
    You got me - try calling REI or the link I posted.
    From the pictures I see, looks easily wide enough, but I cannot say for sure.
    Unfortunately, I found this solution to be the best, then bought a short bed truck and it doesn't fit.
    Check out this rack I have one on the way to me.
    http://www.cdktest.com/scbikeracks/d..._product_id=13
    Will hold 4 bikes in the back of my 05 Tundra
    nice, but nowhere near his price level!
    lots of options
    http://www.utahmountainbiking.com/bikerack/makerack.htm
    I made one of these for the back of my Tacoma. It works well and only cost about $30 plus the tie downs.
    Check out this other thread for more ideas.
    http://forums.mtbr.com/showthread.ph...ght=bike+racks
    3 "fiddy" for short
    Reputation: be350ka's Avatar
    Dec 2004
    I bought the Saris Kool rack for my Tacoma and absolutely love how it works. The hydraulic piston that "locks" the rack to the bed is a great setup. Check one out and rest assured, it is worth the money.
    Oh, yea. It is sooo easy to install and load the bikes. Then, when you're done with it you can store it in the closet.
    http://www.bikepartsusa.com/product_...=01-122116&r=7
    I saw one in a magazine this weekend that sits along the side of the bed and holds the bike from the side. I'll see if I can find it for you in the next day or so. Said magazine is at the bottom of my suitcase as I just got back from some fun in Idaho with work.
    I have an 04 tundra and I use the Yakima Bedheads that mount to the bed with a single allen bolt - thing C-clamp design. No drilling or marring your truck. They're pretty cheap you can find 'em on ebay.
    Reputation: rbald42's Avatar
    03' Tundra.2X10 pressure treated lumber 2 yakima locking blockheads. 7ft coated steel cable padlocked to each end of the bed behind the cab and run through the frame of each bike. cut up a rubber doormat and glued to bottom of said lumber to avoid sliding.around 100$ even. sprung for the outdoor master locks as the last cheap pad lock rusted shut and had to be dremel cut off the bed
