Best place to get hitch (install too)?- Mtbr.com
Results 1 to 6 of 6
    Feb 2005
    Looking to get a hitch for an Acura RSX hatcback. Curious where folks are buying their hitches and where they're getting them installed?
    Main choices is the Curt and Drawtite/Hidden hitch. I recommend the Curt hitch since the design is better and I'm a bit biased as well based on past experience.
    For your RSX, the install is quite simple. Although it does not require any drilling, it isn't exactly a direct bolt on. It requires you to fish in a washer and bolt through an already pre-drilled hole.
    https://www.curtmfg.com/masterlibrar...111540_INS.PDF
    If you're planning on doing it yourself, make sure to have an extra fishwire (just in case one breaks) and a retractable magnet (if you lose the washer/bolt in the frame). Other than that, it shouldn't take longer than 30 minutes for a shop to install it. FYI, make sure either you or the installer use loc-tite on the bolt.
    Feb 2005
    Thank you for the vehicle-specific info! (and noticed you're a fellow Ibis owner)
    Reputation: Wingspan's Avatar
    I just bought my hitch last week from Trailer hitch, hitches and bike rack (800)298-8924. Excellent service, I ordered my hitch on Thursday and it was on my doorstep on Friday afternoon.
    and... on my car... did it on my driveway
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I would just research and see what the estimated difficulty and time is. You can usually get a good idea from that. Usually the listed times are pipe-dreams, but you can get an idea by if it tells you to drill holes and do all sorts of other complex stuff. Obviously it will take a lot longer under those circumstances. Often two different hitches will have different installation procedures, one may be easier one harder. If you plan to just use it for a bike rack, that may allow for the simpler one, due to not having to really use it to tow stuff. Mine (not for an acura, but a sportscar) was an honest 45 minutes, not complex, and relatively easy. Some are not. U-haul is usually a decent option to get one put on. Avoid car dealers at ALL COSTS. They charge insane amounts for the factory hitch and installation.
