Bbike won't fit on rack- Mtbr.com
Results 1 to 5 of 5
    Apr 2013
    i have a Thule hitch rack for 2 bikes. I don't know what model rack. I rarely carry a second bike. However, when I recently tried, I discovered that because the top tube was not streight, the frame of the second bike was too small to easily fit onto the rack.
    I don't plan on carrying this second bike often and thus don't want to spend the money for a different rack.
    My idea for the few times I will carry the second bike is to put the front of the bike on the bar of the rack as it should be and then tie the bike under the other bar and then tie the whole mess so it doesn't swing.
    Any thoughts? Am I making a mistake? Is there a better way?
    Bicyclochondriac.
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Hook one arm of the rack right behind the fork and under the downtube. Put the other arm through the small frame. This usually works for small bikes. Keep in mind I can't see what you're doing so this is just a suggestion.
    I'm a mountain bike guide in southwest Utah
    Apr 2013
    Quote Originally Posted by Silentfoe View Post
    Thanks. I'll try that. I also tested hanging the bike using webbing and it appears to work.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by Bruce in SoCal View Post
    Talk about a recipe for dropping the bike on the freeway. Do it the way silentfoe says, buy a top tube adapter bar, or buy a platform hitch rack. Anything else is sketch.
  1. Roof rack vs hitch rack vs trunk rack..?
    By F29Lefty in forum Cars and Bike Racks
    Last Post: 10-16-2015, 07:18 AM
  2. North Shore 4 bike rack. Can you lock the bikes to the rack?
    By Rated R in forum Cars and Bike Racks
    Last Post: 01-11-2015, 07:50 PM
  3. Help me identify these bike rack parts! For a custom motorcycle rack!
    By doyouwantaspoon in forum Cars and Bike Racks
    Last Post: 06-26-2014, 11:34 PM
  4. Roof rack or hitch mount rack for Ford Escape?
    By Birdymkr in forum Cars and Bike Racks
    Last Post: 04-08-2014, 09:44 AM
  5. Rhino-Rack Discovery Roof Rack Bike Carrier
    By Doug_ID in forum General Discussion
    Last Post: 04-18-2012, 07:54 AM
