Anybody ever fix something on your car with bike parts??- Mtbr.com
Results 1 to 14 of 14
    Just fixed a pivot in my cars shifter with a chainring bolt I wish I had pictures of it, but that's not something I was thinking of at 12:30AM.
    Anybody else use bike parts to fix something on your car??
    29 and Single
    Um, no.
    Some days you eat the bar, some days the bar eats you.
    Jury rigged a remote hood release with a brake cable once.
    ballbuster
    Reputation: pimpbot's Avatar
    Quote Originally Posted by Bryank930
    I once held a window crank mechanism with an old road bike brake shoe. Turns out my old beater Jetta window crank plate needed an M6 1.0 thread, and all I had handy was a brake shoe.
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    i just swapped out my steering wheel with a 110mm stem and some riser bars. i wired my brake pedal to some old avid brake levers and rigged my manual transmission to some old xt shifters.
    the gas pedal and clutch are now a set of xt cranks with spd pedals. problem i'm having now is i have to wear my bike shoes to drive.
    was thinking of swapping out the bucket seats for a new WTB saddle, but decided against it. i think i'm going to install a 120mm stem so i can recline a couple more clicks.
    Reputation: s0ckeyeus's Avatar
    My car was a bit heavy, so I took out the suspension and switched to V-brakes...
    I finally took a pic of my ghetto work. Looks like it belongs there.
    I didn't have the right length bolts to pull a crank pully on one of my Camrys... turns out the long shock pivot bolts on my bike were perfect for the job.
    -Charlie
    The throttle cable on my 1960 Willys was a tandem brake cable.
    Nope, but I have used r/c car clutch shims to space out disc brake calipers. They're the right diameter and come in different thicknesses.
    Reputation: nachomc's Avatar
    Replaced a broken wheel stud with a Ti skewer.
    :wq
    Sure
    175mm square taper cranks
    they work pretty well.
    888 Direct mount stems to hold the big Hella's in place
    Also made this "dog Mat" out of road bike tires
    SSolo, on your left!
    Quote Originally Posted by patineto
    Sure
    Now that is cool!
    Get off the couch and ride! :)
    Jan 2003
    My old Focus had a shift cable for a throttle cable.
