Any recs. for a frame adapter bar?- Mtbr.com
Results 1 to 13 of 13
    Was thinking of getting a Yakima or Thule? .......or is this a bad idea all together, and I just need to break down and buy a hitch?
    Reputation: alexplantman's Avatar
    bump from a year ago or so, since I have the same question.. ...
    I am going to mount two Specialized Hard tails... so the top frame isn't as slanted as on a f/s... Do you need the top tube frame adapter? Amazon has one from Yakima, Sparehand, and Swagman.
    Better 2 ask 4 pardon than 2 ask for permission. Recall that nxt time U feel you have 2 ask ur wife if U can buy something
    Reputation: rogsim's Avatar
    May 2012
    If you can go the hitch route, that would be ideal (well for me personally). I have the Yakima TubeTop (which I don't use anymore because I now have a platform rack) and honestly they're all pretty much the same. You can't go wrong with a Yakima, Thule or the other brand Performance sells. They all work the same.
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    Get the Thule 982xt...it's the easiest to open and close, and in my opinion, side by side with the Yakima Tubetop.
    I ended up getting my adapter bar from Rage Powersports, and it works great for me. It has a thick rubber connection for the front and seat tube...... ($20) shipped if your still looking?
    Reputation: joeinchi's Avatar
    Jun 2010
    I used a Hollywood adapter bar on a previous bike and had some problems with its design. If the Rage is similar, the handlebar hops in the collar and could twist and possibly slip out. I remedied the situation by drilling a hole through the tubes and installing a bolt to eliminate the twisting.
    ballbuster
    Reputation: pimpbot's Avatar
    Quote Originally Posted by joeinchi View Post
    Or just put a bungee cord around your front wheel to your frame.
    These adapters... aren't they all basically the same thing? I mean, it ain't a space shuttle here.
    Just be sure your front wheel doesn't hang down so low it catches on the ground on driveways and ramps. I had one of these for my old Stumpjumper FSR, and I tweaked a front wheel once when my bud's car hit a good sized bump at speed. I started taking my front wheel off and putting it inside.
    Heck, I think I still have two of these bars in my garage somewhere. I oughta craigslist them.
    Dirt Bike Craig
    Reputation: FMX_DBC's Avatar
    Quote Originally Posted by pimpbot View Post
    Interestingly enough, I need two of those...
    Check out my photography on RedBubble http://www.redbubble.com/people/fmxdbc
    Jun 2010
    Good suggestion. I've definitely done that, too, to prevent the handlebar from twisting. But, IME, that doesn't prevent the adapter bar from twisting and possibly opening up.
    I think you're right that most of these adapters share the same design ... not so great. And the handlebars simply rest on top of the front collar. Ugh!
    FMX_DBC- I also added some velcro straps to prevent the handlebars from hopping the second your car hits a bump. It worked great once I made these changes but, IMHO, it's not a great solution out of the box.
    May 2012
    I have my Yakima TubeTop sitting around collecting dust as well since I got platform hitch rack.
    Dirt Bike Craig
    how much would you sell it for?
    Reputation: iamunchien's Avatar
    Quote Originally Posted by rogsim View Post
    sell it to meeeeeee.
    meow.
