Any options for soft tonneau cover with roof rack style bars above?- Mtbr.com
Results 1 to 12 of 12
    Looking to carry 4 bikes above the bed of my truck while being able to utilize the bed space and have a soft tonneau cover. Any ideas?
    since 4/10/2009
    Reputation: Harold's Avatar
    dunno about soft tonneau covers, but there are a number available that work with the retractable type.
    This is just one example I turned up on a quick google search.
    http://www.truckcoversusa.com/american-rack-system/
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Is any of the top rail exposed still with the cover on?
    If so, you can simply add towers dropped through the rails and add a load bar or two and the racks of your choice.Name:  asset.jpeg
    Quote Originally Posted by Shark View Post
    Not sure as I currently have a cap and am researching ideas at this point. And do you mean dropped through the stake holes?
    Reputation: drag_slick's Avatar
    Sep 2004
    A buddy of mine put these on the top of the bed rails to mount a foot pack, load bars, etc.
    https://www.thule.com/en-us/us/roof-...s-60-_-6432999
    This is what I had on my old Dakota.
    Truck Rack (Slick Rack)- Mtbr.com
    Minnesota Off Road Cyclists www.morcmtb.org
    Feb 2006
    Quote Originally Posted by shades9323 View Post
    Just the towers drilled through the rail.
    Any options for soft tonneau cover with roof rack style bars above?-4330.jpg
    May 2012
    I could add two more 1up trays to have 4 bikes.
    I bolted O-channel to the top of the rails and have attached the cross bars to that.
    Sent from my iPad using Tapatalk Pro
    Quote Originally Posted by kf9yr View Post
    I ended up ordering a pace Edwards UltraGroove Tonneau Cover with the rail kit. Decided I like the security of the retractable. Now trying to figure out trays. How do you like the 1UP trays? Are the easy to use and secure? I am leaning toward the inno tire hold trays right now.
    Professional Crastinator
    Reputation: Fleas's Avatar
    Any options for soft tonneau cover with roof rack style bars above?-100_5012.jpgAny options for soft tonneau cover with roof rack style bars above?-20170509_194102%5B1%5D.jpg
    Any options for soft tonneau cover with roof rack style bars above?-fatrack.jpgAny options for soft tonneau cover with roof rack style bars above?-100_0253.jpg
    Any options for soft tonneau cover with roof rack style bars above?-20170812_123825.jpg
    ProRac + Truxsport roll-up tonneau + assortment of Swagman Race Ready racks, boat rack, roof pod, etc.
    The ProRac and Truxsport tonneau were a matched set. The hardware jives perfectly.
    If I get creative, I can do 5 or 6 bikes (I'd have to borrow racks), or a boat + 3 bikes, or several boats, or a roof pod + 3 bikes - still pull a camper, or add a hitch rack for 4 more bikes - and have a bed full of useless crap.
    The stainless bolts on the outside are seized even though I used anti-seize when I put it together, but the inside clamps are in good shape. I think I broke just 1 when I moved it from the old Colorado to the less-old Colorado. Some of the hardware I bought and some of the slider nuts in the tracks I just made from aluminum bar (the seized ones). It is at least 8 years old. Reconfiguring it has been pretty easy over the years as forks/dropouts/axles have changed and I got new racks.
    -F
    It's never easier - you just go faster.
    May 2012
    I really like the 1-up trays. They are very low-profile when they’re not being used.
    I go through the car wash all the time and no problems.
    They also hold my bikes very securely. I’m not sure where you live but the AZ sun does a number on plastic and the all-aluminum construction makes that a non-issue.
    Made in the USA is another plus in my opinion.
    Good Luck!
    since 4/10/2009
    Good Luck!
    I have a couple that I like a lot, too.
    Only issue is that the arms rattle a bit. I keep meaning to wrap the offending areas with old tubes, but keep forgetting.
    Sent from my VS995 using Tapatalk
  1. DIY Tonneau Cover Ideas?
    By Cornfield in forum Off Camber (off topic)
    Last Post: 06-19-2017, 06:46 PM
  2. Truck Tailgate pad with tonneau cover?
    By Whip Chop! in forum Cars and Bike Racks
    Last Post: 04-18-2017, 09:06 AM
  3. Roof rack vs hitch rack vs trunk rack..?
    By F29Lefty in forum Cars and Bike Racks
    Last Post: 10-16-2015, 07:18 AM
  4. Dimondback Tonneau cover Trek Farley 5
    By Gruf in forum Cars and Bike Racks
    Last Post: 10-10-2015, 07:43 PM
  5. Home made bike rack compatible with Undercover Tonneau cover
    By Rock75 in forum Cars and Bike Racks
    Last Post: 08-07-2014, 11:18 PM
